    updated installer script available for testing
    211 Posts 18 Posters 238.8k Views 19 Watching
      sdetweil
      I have updated the installer script…
      correct node/npm version checks failing
      check and install npm < — this is the big one
      fix pm2 setup for current userid
      (on my system it isn’t pi)
      curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh | bash
      let me know
      edited: Jan 4, 2020 move distro from dropbox to github
      Mykle1M M 3 Replies Last reply Reply Quote 3
        sdetweil @sdetweil
        @sdetweil this installer script is now the script in 2.10…
        I will close/lock this topic in a couple days
          Mykle1 Project Sponsor Module Developer @sdetweil
          The next installation I do, I will. Not that it helps you now. :-/
            sdetweil @Mykle1
            @Mykle1 no problem… install hasn’t been fixed for a while, and more and more new users are having trouble due to the npm issue… time to try and fix that… and my system isn’t a pi… but an odroid , with a new sbc system coming… (Nvidia Jetson Nano) so I want to be ready…
              I tip my hat to you for taking the initiative. I could, if you wanted, take a laptop with ubuntu on it and test it for you now. It’s not a big deal. Just say the word. :thumbsup:
                I’m just gonna do it. I’ll report back in a bit.
                EDIT MINUTES LATER:
                It appears I jumped the gun here. This was intended for Pi users only? Sorry bro. The only Pi I have is running my first mirror and I wouldn’t touch that.
                pop@CQ57:~$ bash -c “$(curl -sL https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0)”
                bash: “#!/usr/bin/env: No such file or directory
                pop@CQ57:~$
                  sdetweil @Mykle1
                  @Mykle1 try now… I commented out the PI test
                    Will do. Gonna do that now. I will report back.
                    EDIT:
                    I used the same url and got the same error as noted above. Perhaps I am doing something wrong?
                      sdetweil @Mykle1
                      @Mykle1 redo the cut/paste… the original had the funky double quotes in it…
                        Just to be clear. I ran the original command twice. No luck.
                        I copy and pasted it a third time when you said you have commented out things. No luck same error.
                        Then I copied the script itself into a file and renamed it raspberry.sh and made it executable by chmod u+x raspberry.sh and saved that to home and ran the install script again. No luck. Same error.
                        I’m sorry I’m not being much help
                          sdetweil @Mykle1
                          @Mykle1 ok, again… that was the 1st line… why that way, not sure… try again
                          but I know why it was done, altho I don’t think that is needed…
                          • 21
                          • 22
                          • 1 / 22
