Problems with calender and Nextcloud
@kruf so two things to test
with the calendar URL, open a browser on the pi, and put in the URL… it should download the ICS file
if not, u need to solve this part. Mirror does not run as any particular user, so it needs access without
credentials (unless they are part of the actual url) -
I helped another user who did some download process, and then use the ics file locally, and had a similar problem. it turned out the ics reader is expecting windows line ends (cr+lf, \r\n), but the file had only unix line ends (lf, \n). so he had to do a unix2dos conversion as part of the download process
@bdream
I tried your holiday calender in hessen, and it works. The standart calender also works just fine. -
@kruf There is no download, it says "its a webdav interface and you need a client for it.
Do you know how to do the conversion? -
@kruf
I use Nextcloud and have URL like this working.url: "https://NAME:[email protected]/Nextcloud/remote.php/dav/calendars/CALENDARNAME/contact_birthdays?export" url: "https://NAME:[email protected]/Nextcloud/remote.php/dav/calendars/CALENDARNAME/pers%c3%b6nlich?export"
May this help you
@bdream has CALENDERNAME to be changed? Or is the phrase after that important?
@kruf said in Problems with calender and Nextcloud:
All UPPERCASE need to change as your calendar.
Exml for the birthdays from my personal calendar:url: "https://NAME:[email protected]/Nextcloud/remote.php/dav/calendars/myname/pers%c3%b6nlich?export"
You have to change
NAME -> name you access your calendar
PASSWORD -> your Password
DOMAIN.TLD -> the url where ever you have your domain with nextcloud installed
!!! If you don’t use default installation of nextcloud you might change Nextcloud also!!!
CALENDARNAME -> How you named the calendar (expl.: myname, yourname, yourwivesname, yoursonsname…)I have different calendars for all people in my family so I have for each calendar diffent NAME, PASSWORD, CALENDARNAME
hey together,
i have the same issue here, but on my side i had a working system in the past.
My MagicMirror was broken and offline for half an year. Now he is up and running. I made an update to the current MM Version. For Nextcloud i am always on the current version.
So, now the problem is that on MM no Calender content will shown. I did not change somethink on the configuration. I use the same links what you mentioned here. When i put it in a browser i can download the ICS file and the content is correct.
It is a bit pitty that i had a software update on Nextcloud and MM side. Any ideas what i can test ?
two ways to see things
1… use npm start to start the mirror, not pm2… then messages will be displayed on the terminal window.
you should see the fetcher for calendar created and any errors in the fetch process
2. on the Mirror UI do ctrl-shift-i to open the developers window, and then select the tab labeled console, and scroll up… you can also filter the messages, by putting part of the module name in the filter field.
‘calendar’ for example (no quotes) -
Great, Thanks for the instructions.I try step one and obviously i get an error during loading calender content (Link to calender replaced):
Calendar Error. Could not fetch calendar: CALENDER LINK { Error: write EPROTO 19413 98784:error:1409442E:SSL routines:ssl3_read_bytes:tlsv1 alert protocol version:../../vendor/node/deps/openssl/openssl/ssl/record/rec_layer_s3.c:1407:SSL alert n umber 70 at WriteWrap.afterWrite [as oncomplete] (net.js:833:14) errno: 'EPROTO', code: 'EPROTO', syscall: 'write' }
For Step 2 i have the problem to have only access with an putty terminal at the moment.
Any idea so far what the error message means ?
