    BG Animation with CSS
    Scheduled Pinned Locked Moved Showcase
    11 Posts 6 Posters 5.0k Views 6 Watching
    • Piranha1605P Offline
      Piranha1605
      Small work accident. The result is a BG animation with CSS only. :face_with_tears_of_joy: :face_with_tears_of_joy: :face_with_tears_of_joy: :face_with_tears_of_joy:
      Video on You Tube
      body {
        margin: 10px;
        position: absolute;
        width: calc(100% - 20px);
        height: calc(100% - 20px);
        margin-bottom: -10px;
        font-size: 20px;
        font-weight: 500;
        line-height: 1.5;
        color: #606060;
        background: url("bg/bg7.jpg");
        background-blend-mode: hard-light;
        -webkit-animation: hue-rotate 10s linear infinite;
      html {
        cursor: default;
        overflow: hidden;
        background: linear-gradient(233deg, #e56420, #c22525, #3d9c31, #37bbde);
      header {
        text-align: center;
        font-size: 20px;
        padding:8px;
        border-radius: 5px;
        outline: none;
        border: none;
        background-image: linear-gradient(#28D2DE 0%, #1A878F 100%);
        color: #FFF;
        text-transform: uppercase;
        text-shadow: #000 0px 1px 5px;
        border: 1px solid #000;
        opacity: 0.7;
        box-shadow: 0 8px 6px -6px rgba(0, 0, 0, 0.7);
        border-top: 1px solid rgba(255, 255, 255, 0.8) !important;
      .dimmed {
        color: #FFF;
      .normal {
        color: #FFF;
      .bright {
        color: #FFF;
       .module {
        font-size: 20px;
        padding:8px;
        font-weight: 400;
        border-radius: 5px;
        box-shadow: inset 4px 6px 10px -4px rgba(0, 0, 0, 0.3), 0 1px 1px -1px rgba(255, 255, 255, 0.3);
        background: rgba(0, 0, 0, 0.2);
        outline: none;
        border: none;
        border: 1px solid black;
        color: #6E6E6E;
      @keyframes hue-rotate {
        from {
          -webkit-filter: hue-rotate(0);
          -moz-filter: hue-rotate(0);
          -ms-filter: hue-rotate(0);
        to {
          -webkit-filter: hue-rotate(360deg);
          -moz-filter: hue-rotate(360deg);
          -ms-filter: hue-rotate(360deg);
      @-webkit-keyframes hue-rotate {
        from {
        to {
      Piranha1605P 1 Reply Last reply Reply Quote 4
      • lavolp3L Offline
        lavolp3 Module Developer
        Great idea. I would set the animation duration much longer but it looks great.
        If I were you I would include all of this onto the MMM-fast-css module.
        I would also add possibilities for arrangement of the modules.
        Another user has posted an example of the modules in grid display. Could also be implemented as an option in the module couldn’t it?
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        S Piranha1605P 2 Replies Last reply Reply Quote 0
          sdetweil @lavolp3
          @lavolp3 have u tried this on a 4k screen. animations are really slow there.
          Piranha1605P 1 Reply Last reply Reply Quote 0
            Piranha1605 @sdetweil
            @sdetweil Tomorrow I will test all the monitors in the house with it. It runs smoothly on the Pi and on the laptop. I have not yet tried it on the TV.
              Piranha1605 @lavolp3
              @lavolp3
              I will adapt it further and then add it to the module. The arrangement of the modules will be resolved via the config. What I will do is install the day and night switches that change the designs.
                sdetweil @Piranha1605
                @Piranha1605 cool. I have 55 in tv, 4k, and one animation that is troublesome box-shadow inset only on one edge
                  I just tested it in the living room. It runs smoothly if you set the time to 5s. The problem is now the discussion with my wife why I now work on the large TV in the living room every evening. :)
                  You Tube Video
                  TV
                  Samsung GQ75Q60RGT
                  cowboysdudeC 1 Reply Last reply Reply Quote 1
                    Piranha1605 @Piranha1605
                    @Piranha1605 said in BG Animation with CSS:
                    Video on You Tube
                    html {
                    cursor : default;
                    overflow : hidden;
                    body {
                    margin : 10px;
                    position : absolute;
                    width : calc(100% - 20px);
                    height : calc(100% - 20px);
                    margin-bottom : -10px;
                    font-size : 20px;
                    font-weight : 500;
                    line-height : 1.5;
                    color : #FFF;
                    background : url("bg/bg11.jpg");
                    width : 100%;
                    height : 100vh;
                    background-size : cover;
                    background-blend-mode : hard-light;
                    animation : hue-rotate 10s linear infinite;
                    header {
                    text-align : center;
                    font-size : 20px;
                    padding : 8px;
                    border-radius : 5px;
                    outline : none;
                    border : none;
                    color : #FFF;
                    text-transform : uppercase;
                    text-shadow : 0 1px 5px #000;
                    border : #000 solid 1px;
                    opacity : 0.7;
                    box-shadow : 0 8px 6px -6px rgb(0, 0, 0, 0.7);
                    border-top : 1px solid rgb(255, 255, 255, 0.8) !important ;
                    .dimmed {
                    color : #FFF;
                    .normal {
                    color : #FFF;
                    .bright {
                    color : #FFF;
                    .module {
                    font-size : 20px;
                    padding : 8px;
                    font-weight : 400;
                    box-shadow : 4px 6px 10px -4px rgb(0, 0, 0, 0.3) inset, 0 1px 1px -1px rgb(255, 255, 255, 0.3);
                    background : rgb(0, 0, 0, 0.2);
                    outline : none;
                    border : none;
                    border : black solid 1px;
                    color : #6E6E6E;
                    from {
                    filter : hue-rotate(0);
                    to {
                    filter : hue-rotate(360deg);
                      datamunk
                      Unrelated to the animation, but how do you do those borders around your modules? In your post, is it the .module settings ?
                      UPDATE: I added to my css and it worked, cool! Been trying to find this for a while. Thanks for helping!
                      .module {
                      font-size: 20px;
                      padding:8px;
                      font-weight: 400;
                      border-radius: 5px;
                      outline: none;
                      border: none;
                      color: #6E6E6E;
                        cowboysdude Module Developer @Piranha1605
                        @Piranha1605 Late to this party but MAN your background looks really awesome!
