    MMM-DynamicWeather
    problems running mm
    13 Posts 3 Posters 3.0k Views 3 Watching
      George @scottcl88
      @scottcl88 Hi,
      an hour after the mirror was turned on, MMM-News disappeared (nothing was displayed), MMM-ImagesPhotos disappeared and the clock stopped. I disabled DynamicWeather, I restarted and now everything is ok. I think there is a conflict.
      I’ve had mirrors for almost a year, it’s always worked perfectly, it’s the first time something like this has happened.
        scottcl88 @George
        @george I am having trouble reproducing. I installed MMM-News and MM-ImagesPhotos and have been running just fine for several hours and see all modules.
        I did just push a new update to MMM-DynamicWeather with more logging and error handling, can you get latest and see if that does anything?
        A few more things :
        • I’ve posted my config.js, do you see anything notably different with yours that I should try?
          • https://justpaste.it/9qkn1
        • Can you verify your API key works by going to the link in your browser:
          • https://api.openweathermap.org/data/2.5/weather?appid=API_KEY&id=LOC_ID
          • You should be able to actually see the weather data.
        • Have you reviewed this post about troubleshooting?
          • https://forum.magicmirror.builders/topic/86/how-to-troubleshoot
        G 1 Reply Last reply Reply Quote 0
          George @scottcl88
          @scottcl88 Hi,
          I reinstalled the module an hour ago on the mirror that has the most modules and the mirror work. :)
          Many thanks!
            Sceetch
            the animations of the modul are always in foreground.
            f.e. If i play a video in fullscren, the clouds in front of it.
            Is it possible to change this?
              scottcl88 @Sceetch
              @sceetch Well that’s what the zIndex option is supposed to, but I don’t believe it works. As an alternative, you can change the opacity to something lower and be able to see through the animations.
              Unfortunately I believe I would need to spend a lot more time re-writing the animations to get the zIndex thing to work. I might try to look into that later, or maybe someone from the community can take a try.
              There is an active issue for that: https://github.com/scottcl88/MMM-DynamicWeather/issues/36
