    MMM-Strava ID Unauthorized
    Scheduled Pinned Locked Moved Health
    17 Posts 4 Posters 3.7k Views 4 Watching
    • BerkSmash1984B Offline
      BerkSmash1984 @BerkSmash1984
      @mumblebaj I did attempt a reinstall of the MMM-Strava module but can certainly do it again. Is best method to rm-rf the MMM-Strava modiue folder and then redo the steps listed in the Github for MMM-Strava?
        sdetweil
        @BerkSmash1984 u can edit your posts… don’t have to leave pad text, wrong info, bad tag…
        BerkSmash1984B 1 Reply Last reply Reply Quote 0
          BerkSmash1984 @sdetweil
          @sdetweil my bad, thanks! I corrected my post
            sdetweil @BerkSmash1984
            @BerkSmash1984 not bad, maybe you didn’t know. lol
              BerkSmash1984
              @mumblebaj just removed the MMM-Strava module and installed from scratch. Still seeing the same issue. Would you by chance be able to do any direct troubleshooting with me? I am on discord in the MM channel and can dm you in there, if you have any free time at any point.
              Note: when I click the authorize button a the Stava auth site after being redirected there from my MM on the RPI, in Electron, I see this generated:
              [03.05.2022 10:13.13.537] [ERROR] Whoops! There was an uncaught exception…
              [03.05.2022 10:13.13.538] [ERROR] Error [ERR_HTTP_HEADERS_SENT]: Cannot set headers after they are sent to the client
              at new NodeError (node:internal/errors:371:5)
              at ServerResponse.setHeader (node:_http_outgoing:576:11)
              at ServerResponse.header (/home/jberk1984/MagicMirror/node_modules/express/lib/response.js:776:10)
              at ServerResponse.location (/home/jberk1984/MagicMirror/node_modules/express/lib/response.js:893:15)
              at ServerResponse.redirect (/home/jberk1984/MagicMirror/node_modules/express/lib/response.js:931:18)
              at /home/jberk1984/MagicMirror/modules/MMM-Strava/node_helper.js:185:10
              at /home/jberk1984/MagicMirror/modules/MMM-Strava/node_helper.js:451:5
              at node:fs:2122:7
              at FSReqCallback.oncomplete (node:fs:188:23) {
              code: ‘ERR_HTTP_HEADERS_SENT’
              So the issue seems to be whatever is causing that. I never do see the token.js being generated after clicking the authorize button. My client and secret ID are correct in my config.js file (can’t tell you how many times I have checked to make sure)
                @BerkSmash1984 said in MMM-Strava ID Unauthorized:
                so, this error is typically caused by some code doing two sends for an incoming request
                the module sets up a little server to receive and does a redirect response…
                but this could be an async problem
                start sending one response, continue while it runs and then fall into another send… oops…
                I only made a cursory look at the code. i have done similar things in some of my coding here and on other platforms.
                I don’t ‘see’ it, but there is a library in there too
                this says it is handling a callback on request complete,
                line 185 is in the handling of the token auth . but the stravea lib is calling back into the function (function (err, payload, limits) at line 176
                so the node_helper called strava, who called us back at the function on line 185 ( (err, data) => { (err, data) => { ) which does a redirect… WHILE the strava request to get the auth token handler is still active…
                			strava.oauth.getToken(authCode, function (err, payload, limits) {
                				if (err) {
                					console.error(err);
                					res.redirect(`/${self.name}/auth/?error=${err}`);
                					return;
                				// Store tokens
                				self.saveToken(clientId, payload.body, (err, data) => {    // line 185
                					// redirect route
                					res.redirect(`/${self.name}/auth/?status=success`);
                line 451, is in the end of the saveFile() function, supposedly to save the tokens.json
                	saveToken: function (clientId, token, cb) {
                		var self = this;
                		this.readTokens();
                		// No token for clientId - delete existing
                		if (clientId in this.tokens && !token) {
                			delete this.tokens[clientId];
                		// No clientId in tokens - create stub
                		if (!(clientId in this.tokens) && token) {
                			this.tokens[clientId] = {};
                		// Add token for client
                		if (token) {
                			this.tokens[clientId].token = token;
                		// Save tokens to file
                		var json = JSON.stringify(this.tokens, null, 2);
                		fs.writeFile(this.tokensFile, json, "utf8", function (error) {
                			if (error && cb) {
                				cb(error);
                			if (cb) {
                				cb(null, self.tokens);  // line 451  --- this calls back into the  ( (err, data) =>)  function
                  rmonteroc
                  @BerkSmash1984 did you ever fixed this issue?
                  I just had the same issue, and it turns out it was a permissions issue in the MagicMirror folder, I changed the permissions of the folder and re-authorized, it’s now working.
                  Best regards
