MMM-OpenWeatherMapForecast stuck on Loading....
@postb8822 thanks for the heads up
I synched, changed and pushed pr back
I followed your https://github.com/sdetweil/MMM-OpenWeatherMapForecast
– Installation –
Navigate into your MagicMirror modules folder and execute:git clone https://github.com/MarcLandis/MMM-OpenWeatherMapForecast.git
Enter the new MMM-OpenWeatherMapForecast directory and execute :
#npm installAfter that updated the code and restarted service:
Mirror@raspberrypi:~/MagicMirror/modules/MMM-OpenWeatherMapForecast $ sudo vi …/…/config/config.js
…Code below with hiddne API…
module: “MMM-OpenWeatherMapForecast”,
header: “Weather”,
position: “top_right”,
classes: “default everyone”,
disabled: false,
apikey: “XXXXXXXXXXXXXXXXXXX”,
latitude: “47.690900”,
longitude: “43.587770”,
iconset: “4c”,
concise: false,
forecastLayout: “table”,
},$ sudo systemctl restart pm2-Mirror.service
Getting below error:
0|mm | [2024-08-09 12:10:19.206] [LOG] [MMM-OpenWeatherMapForecast] 9-Aug-24 12:10 ** ERROR ** null
0|mm | [2024-08-09 12:15:19.663] [INFO] Newsfeed-Fetcher: Broadcasting 25 items.
0|mm | [2024-08-09 12:20:16.801] [LOG] [MMM-OpenWeatherMapForecast] 9-Aug-24 12:20 ** ERROR ** null -
Just changed OS to Bookworm and reinstalled MM, stuck with weather modules loading…
For me, @postb8822 's 29th April 2024 suggestion worked just fine, thank you :)
