    Default calendar is just loading! (Newbie)
    23 Posts 2 Posters 4.4k Views 2 Watching
      Max 0 @sdetweil
      @sdetweil I just did that?
      Is that correct? yes.
        sdetweil @Max 0
        @Max-0 but you did not set the debug in config.js first
        M S 2 Replies Last reply Reply Quote 0
          Max 0 @sdetweil
          @sdetweil If you mean to add “DEBUG” in the config list, i did that but i can do it again and send you another mail
            sdetweil @sdetweil
            yes. there should be about 1000 lines of output in the file
              Max 0 @sdetweil
              @sdetweil I’ve definitely set Debug to the log level list, but I’m still getting those same some file.txt lines
                sdetweil @Max 0
                @Max-0 show me the loglevel from config.js, should look line this
                	logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"],
                  Max 0 @sdetweil
                    sdetweil @Max 0
                    @Max-0 ok, when you run npm start you should see stuff like this
                    default US holidy cal, one event
                    UG] Event:
                    {"type":"VEVENT","params":[],"summary":"Labor Day","start":"2023-09-04T05:00:00.000Z","datetype":"date","end":"2023-09-04T05:00:00.000Z","location":"United States","description":"Visit https://c>
                    [24.08.2023 15:01.51.477] [DEBUG] start: Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
                    [24.08.2023 15:01.51.477] [DEBUG] end:: Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
                    [24.08.2023 15:01.51.477] [DEBUG] duration: 0
                    [24.08.2023 15:01.51.477] [DEBUG] title: Labor Day
                    [24.08.2023 15:01.51.477] [DEBUG]  if no tz, guess based on now
                    [24.08.2023 15:01.51.485] [DEBUG] initial tz=America/Chicago
                    [24.08.2023 15:01.51.485] [DEBUG] corrected tz=America/Chicago
                    [24.08.2023 15:01.51.485] [DEBUG] start date/time=Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
                    [24.08.2023 15:01.51.486] [DEBUG] start offset=-300
                    [24.08.2023 15:01.51.486] [DEBUG] start date/time w tz =Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
                    [24.08.2023 15:01.51.486] [DEBUG] event date=Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
                    [24.08.2023 15:01.51.487] [DEBUG] event offset=-300 hour=0 event date=Mon Sep 04 2023 00:00:00 GMT-0500 (Central Daylight Time)
                    [24.08.2023 15:01.51.487] [DEBUG] adjustHours=0
                    [24.08.2023 15:01.51.487] [DEBUG] Processing entry...
                    [24.08.2023 15:01.51.487] [DEBUG] Event:
                      Max 0 @sdetweil
                      @sdetweil If you mean this should be in the somefile.txt, I double checked your instructions and did it a few times but I´m getting over and over the same text in the file! But I do not fully understand what you mean by 1 event in the calendar. Also when I check the dev console in the mirror, there are some errors which say “Refused to apply style […]”/“Error on loading stylesheet: css/custom.css” (Idk if that is important)
                        sdetweil @Max 0
                        @Max-0 I am just showing 1 event from the debug log
                        • 2 / 3
