MMM-birthdays
@sdetweil Hello, thank you for the module recommendation. I’ll definitely take a closer look at it. Could you please share a screenshot that includes the icon and birthdays?
only shows this month forward to end of the year, birthdays prior to today in this month are greyed out
multiple people can have the same BD… but same or different ages listed together…this image is the calendar sheet with the month day number on it
the module settings for this image are
{ module: "birthdaylist", disabled: false, position:'top_left', config: { language: "en", dimmEntries: true, // true: dims entries and the associated // symbol when the date has expired. // false: dont display entries and the associated // symbol when the date has expired. initialLoadDelay: 0, // How many seconds to wait on a fresh start up. // This is to prevent collision with all other modules also // loading all at the same time. This only happens once, // when the mirror first starts up. updateDelay: 5, // How many seconds after midnight before a refresh // This is to prevent collision with other // modules refreshing at the same time. currentMonthOnly: false, // will show birthdays for the current month only if true maxEntries: 0, // maximum entries to show, default is all dateFormat: '', // date format for birthday (default is none), could be 'Do' for 'Sep 12th' ageFormat:'', // some format string for the persons age, '[ n ]' n will be replace by age value debug:false } }
is there a way to include google contacts birthdays, instead of individually adding birthdates?
@sdetweil Thank Sam. :call_me_hand:
I updated MMM-birthdays to add the ability to turn off the module when there are no bdays to show.
Also added the ability to update the name of the title/headerPull request here: https://github.com/amitchone/MMM-birthdays/pull/10
My fork, if you want to install and test it.
https://github.com/jbat66/MMM-birthdaysThank you Adam for writing this module.
