    Error in the calendar module check logs for more details
    14 Posts 4 Posters 418 Views 4 Watching
      nowayto
      Hello,
      I have a problem related to the basic calendar module.
      I use the private.ics from google but sometimes it can’t fetch data.
      It doesn’t happen regularly, only sometimes but this error keep me to keep the keyboard connected for use the CTRL+R function everytime it happen.
      It’s annoying because I hope to forget it completely and just using MM.
      I can reproduce the issue with CTRL+R, every 7/8 refreshes it happen.
      I could not refresh it forever but MM turn off and on every day so… it happen.
      My question is: is it a normal behaviour from google or is there something I did that cause the behaviour?
      I checked pihole also, thinking it could cause issues but it seem not related to it.
      As calendar I use the basic one and the EXT3
      Here is the log, thanks
      /home/MYMM/.pm2/logs/MagicMirror-error.log last 15 lines:
      0|mm | }
      0|mm | }
      0|mm | [2025-06-24 12:47:20.521] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/calendar/ical/MYCAL.ics TypeError: fetch failed
      0|mm | at node:internal/deps/undici/undici:13502:13
      0|mm | at process.processTicksAndRejections (node:internal/process/task_queues:105:5) {
      0|mm | [cause]: AggregateError [ETIMEDOUT]:
      0|mm | at internalConnectMultiple (node:net:1139:18)
      0|mm | at internalConnectMultiple (node:net:1215:5)
      0|mm | at Timeout.internalConnectMultipleTimeout (node:net:1739:5)
      0|mm | at listOnTimeout (node:internal/timers:596:11)
      0|mm | at process.processTimers (node:internal/timers:529:7) {
      0|mm | code: ‘ETIMEDOUT’,
      0|mm | [errors]: [ [Error], [Error] ]
      0|mm | }
      0|mm | }
        Niggich @sdetweil
        @sdetweil Today everything is working normally. I don’t know what happend yesterday.
          sdetweil @nowayto
          @nowayto what version of MagicMirror are you using.
          I added a feature to be able to control that timeout, but set the default at 30 seconds
          See the doc, configuration, mm FetchTimeout environment variable
          But the code should recover by itself.
            sdetweil @nowayto
            N N 2 Replies Last reply Reply Quote 0
              Niggich @sdetweil
              @sdetweil I’ve got the same issue since today. Any other solutions? To change the fetchtimeout doesn’t help.
                sdetweil @Niggich
                @Niggich but it should recover and fetch again
                  nowayto @sdetweil
                  @sdetweil later I’ll try. The version is the last one
                    Niggich @sdetweil
                      sdetweil @Niggich
                      @Niggich network congestion probably… there have been some severe DNS denial of service (hacking) storms in the last few days
                        Niggich @sdetweil
                        @sdetweil Ok, maybe. For me the problem is solved.
                        • S sdetweil has marked this topic as solved
                          nowayto @sdetweil
                          I’m sorry Sam, I didn’t figure out where I have to configure the
                          mmFetchTimeout. Where is it located? Thanks
                          H S 2 Replies Last reply Reply Quote 0
