    Internet Monitor
    108 Posts 27 Posters 125.1k Views 30 Watching
      causerino
      Has this died recently for anyone else? I have made no config changes and it’s stopped working. I’ve tried with a new server ID in case they have changed, but still no luck.
      //New Module Internet Monitor
                              module: 'internet-monitor',
                              position: 'top_left',
                              header: 'SpeedTest',
                              config:{
                                      type: '',
                                      maxTime: 20000,
                                      updateInterval: 0,
                                      verbose: false,
                                      serverId: "40788",
      //                              displayStrength: true,
                                      displaySpeed: true,
                                      strengthIconSize: 50,
                                      maxGaugeScale: 1000,
      S bheplerB 3 Replies Last reply Reply Quote 0
        sdetweil @causerino
        @causerino comment out serverid and let it use any
        add
        to the beginning of the line
          sdetweil @causerino
          @causerino also, please use code blocks for any config data
          paste text
          select text
          then push button that looks like
          I have fixed your post
          • bheplerB Offline
            bhepler Module Developer @causerino
            @causerino said in Internet Monitor:
            I can confirm. It appears that the speedtest service is down. I’m troubleshooting now.
            Update: Problem is with the speedtest-net package. Not sure what the problem is, but it has been down for the past week. They’ve opened an issue with the developers, so hopefully they’ll get around to it. The SpeedTest website and their paid services appear to be working, so something is up with the API.
            I’m looking at my fork of the original repository and the latest changes to speedtest-net and I’m going to prep an update. Once it comes back, I’ll publish.
              causerino @bhepler
              @bhepler said in Internet Monitor:
              Thanks very much for doing this :)
              bugsounetB 1 Reply Last reply Reply Quote 0
              • bugsounetB Offline
                bugsounet Banned @causerino
                Are you really sure ?
                i use it with MMM-SpeedTest
                Result is:
                bheplerB 1 Reply Last reply Reply Quote 0
                • bheplerB Offline
                  bhepler Module Developer @bugsounet
                  @bugsounet - Pretty sure.
                  Here is the GitHub discussion on the problem.
                  EtA: I am having problems installing MMM-SpeedTest.
                  PS J:\Development\MagicMirrors\MagicMirror\modules> git clone https://github.com/bugsounet/MMM-SpeedTest
                  Cloning into 'MMM-SpeedTest'...
                  remote: Enumerating objects: 78, done.
                  remote: Counting objects: 100% (78/78), done.
                  remote: Compressing objects: 100% (66/66), done.
                  remote: Total 78 (delta 33), reused 33 (delta 10), pack-reused 0
                  Unpacking objects: 100% (78/78), 120.78 KiB | 46.00 KiB/s, done.
                  PS J:\Development\MagicMirrors\MagicMirror\modules> cd .\MMM-SpeedTest\
                  PS J:\Development\MagicMirrors\MagicMirror\modules\MMM-SpeedTest> npm install
                  > [email protected] preinstall J:\Development\MagicMirrors\MagicMirror\modules\MMM-SpeedTest
                  > installer/preinstall.sh
                  'installer' is not recognized as an internal or external command,
                  operable program or batch file.
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! [email protected] preinstall: `installer/preinstall.sh`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the [email protected] preinstall script.
                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm WARN Local package.json exists, but node_modules missing, did you mean to install?
                    bugsounet Banned @bhepler
                    npm ERR! errno 1
                    npm ERR!
                    1. the real question is why using v1.6.2 version of SpeedTest library?
                      v2.2.0 solve the problem ;)
                    2. I’m glad that you use windows :anguished_face:
                      Now retry with your pi, a linux env or … with wsl under windows ;)
                    and result is:
                    bugsounet@bugsounet-Kubuntu:~/MagicMirror/modules/MMM-SpeedTest$ npm install
                    Welcome to MMM-SpeedTest v1.0.3
                    > [email protected] postinstall
                    > installer/postinstall.sh
                    Building SpeedTest module, please wait...
                    added 325 packages, and audited 326 packages in 53s
                    28 packages are looking for funding
                      run `npm fund` for details
                    Screenshot:
                    Logs in debug mode:
                    [05.10.2022 17:25.06.650] [LOG]   [SPEED] Ping: 15.028 ms
                    [05.10.2022 17:25.06.664] [LOG]   [SPEED] Ping: 14.293 ms
                    [05.10.2022 17:25.06.679] [LOG]   [SPEED] Ping: 14.511 ms
                    [05.10.2022 17:25.06.694] [LOG]   [SPEED] Ping: 14.89 ms
                    [05.10.2022 17:25.06.709] [LOG]   [SPEED] Ping: 14.293 ms
                    [05.10.2022 17:25.06.778] [LOG]   [SPEED] Download: 32.84 Mbps
                    [05.10.2022 17:25.06.879] [LOG]   [SPEED] Download: 355.00 Mbps
                    [05.10.2022 17:25.06.980] [LOG]   [SPEED] Download: 676.91 Mbps
                    [05.10.2022 17:25.07.081] [LOG]   [SPEED] Download: 705.64 Mbps
                    [05.10.2022 17:25.07.182] [LOG]   [SPEED] Download: 820.78 Mbps
                    [05.10.2022 17:25.07.282] [LOG]   [SPEED] Download: 834.69 Mbps
                    [05.10.2022 17:25.07.383] [LOG]   [SPEED] Download: 853.44 Mbps
                    [05.10.2022 17:25.07.484] [LOG]   [SPEED] Download: 866.43 Mbps
                    [05.10.2022 17:25.07.584] [LOG]   [SPEED] Download: 870.64 Mbps
                    [05.10.2022 17:25.07.685] [LOG]   [SPEED] Download: 874.48 Mbps
                    [05.10.2022 17:25.07.786] [LOG]   [SPEED] Download: 880.78 Mbps
                    [05.10.2022 17:25.07.886] [LOG]   [SPEED] Download: 893.37 Mbps
                    [05.10.2022 17:25.07.987] [LOG]   [SPEED] Download: 893.14 Mbps
                    [05.10.2022 17:25.08.087] [LOG]   [SPEED] Download: 894.11 Mbps
                    [05.10.2022 17:25.08.193] [LOG]   [SPEED] Download: 904.29 Mbps
                    [05.10.2022 17:25.08.294] [LOG]   [SPEED] Download: 906.78 Mbps
                    [05.10.2022 17:25.08.395] [LOG]   [SPEED] Download: 906.16 Mbps
                    [05.10.2022 17:25.08.496] [LOG]   [SPEED] Download: 906.67 Mbps
                    [05.10.2022 17:25.08.596] [LOG]   [SPEED] Download: 910.98 Mbps
                    [05.10.2022 17:25.08.697] [LOG]   [SPEED] Download: 907.16 Mbps
                    [05.10.2022 17:25.08.798] [LOG]   [SPEED] Download: 913.58 Mbps
                    [05.10.2022 17:25.08.898] [LOG]   [SPEED] Download: 915.22 Mbps
                    [05.10.2022 17:25.08.999] [LOG]   [SPEED] Download: 917.29 Mbps
                    [05.10.2022 17:25.09.100] [LOG]   [SPEED] Download: 917.54 Mbps
                    [05.10.2022 17:25.09.200] [LOG]   [SPEED] Download: 923.37 Mbps
                    [05.10.2022 17:25.09.301] [LOG]   [SPEED] Download: 926.05 Mbps
                    [05.10.2022 17:25.09.401] [LOG]   [SPEED] Download: 927.50 Mbps
                    [05.10.2022 17:25.09.502] [LOG]   [SPEED] Download: 927.97 Mbps
                    [05.10.2022 17:25.09.603] [LOG]   [SPEED] Download: 929.40 Mbps
                    [05.10.2022 17:25.09.703] [LOG]   [SPEED] Download: 929.66 Mbps
                    [05.10.2022 17:25.09.804] [LOG]   [SPEED] Download: 926.78 Mbps
                    [05.10.2022 17:25.09.904] [LOG]   [SPEED] Download: 930.49 Mbps
                    [05.10.2022 17:25.10.005] [LOG]   [SPEED] Download: 930.71 Mbps
                    [05.10.2022 17:25.10.106] [LOG]   [SPEED] Download: 932.94 Mbps
                    [05.10.2022 17:25.10.206] [LOG]   [SPEED] Download: 931.10 Mbps
                    [05.10.2022 17:25.10.307] [LOG]   [SPEED] Download: 930.12 Mbps
                    [05.10.2022 17:25.10.408] [LOG]   [SPEED] Download: 930.82 Mbps
                    [05.10.2022 17:25.10.509] [LOG]   [SPEED] Download: 934.36 Mbps
                    [05.10.2022 17:25.10.610] [LOG]   [SPEED] Download: 934.38 Mbps
                    [05.10.2022 17:25.10.710] [LOG]   [SPEED] Download: 935.15 Mbps
                    [05.10.2022 17:25.10.811] [LOG]   [SPEED] Download: 936.19 Mbps
                    [05.10.2022 17:25.10.911] [LOG]   [SPEED] Download: 936.61 Mbps
                    [05.10.2022 17:25.11.012] [LOG]   [SPEED] Download: 936.98 Mbps
                    [05.10.2022 17:25.11.112] [LOG]   [SPEED] Download: 937.93 Mbps
                    [05.10.2022 17:25.11.213] [LOG]   [SPEED] Download: 936.38 Mbps
                    [05.10.2022 17:25.11.313] [LOG]   [SPEED] Download: 938.21 Mbps
                    [05.10.2022 17:25.11.415] [LOG]   [SPEED] Download: 937.11 Mbps
                    [05.10.2022 17:25.11.516] [LOG]   [SPEED] Download: 937.77 Mbps
                    [05.10.2022 17:25.11.616] [LOG]   [SPEED] Download: 938.16 Mbps
                    [05.10.2022 17:25.11.717] [LOG]   [SPEED] Download: 938.23 Mbps
                    [05.10.2022 17:25.11.817] [LOG]   [SPEED] Download: 938.43 Mbps
                    [05.10.2022 17:25.11.918] [LOG]   [SPEED] Download: 938.74 Mbps
                    [05.10.2022 17:25.12.021] [LOG]   [SPEED] Download: 937.84 Mbps
                    [05.10.2022 17:25.12.122] [LOG]   [SPEED] Download: 938.20 Mbps
                    [05.10.2022 17:25.12.224] [LOG]   [SPEED] Download: 938.04 Mbps
                    [05.10.2022 17:25.12.325] [LOG]   [SPEED] Download: 937.89 Mbps
                    [05.10.2022 17:25.12.425] [LOG]   [SPEED] Download: 938.51 Mbps
                    [05.10.2022 17:25.12.526] [LOG]   [SPEED] Download: 938.58 Mbps
                    [05.10.2022 17:25.12.627] [LOG]   [SPEED] Download: 938.34 Mbps
                    [05.10.2022 17:25.12.727] [LOG]   [SPEED] Download: 938.65 Mbps
                    [05.10.2022 17:25.12.828] [LOG]   [SPEED] Download: 939.11 Mbps
                    [05.10.2022 17:25.12.928] [LOG]   [SPEED] Download: 938.53 Mbps
                    [05.10.2022 17:25.13.029] [LOG]   [SPEED] Download: 939.36 Mbps
                    [05.10.2022 17:25.13.129] [LOG]   [SPEED] Download: 939.51 Mbps
                    [05.10.2022 17:25.13.230] [LOG]   [SPEED] Download: 939.49 Mbps
                    [05.10.2022 17:25.13.330] [LOG]   [SPEED] Download: 939.04 Mbps
                    [05.10.2022 17:25.13.431] [LOG]   [SPEED] Download: 939.68 Mbps
                    [05.10.2022 17:25.13.532] [LOG]   [SPEED] Download: 939.33 Mbps
                    [05.10.2022 17:25.13.632] [LOG]   [SPEED] Download: 940.43 Mbps
                    [05.10.2022 17:25.13.733] [LOG]   [SPEED] Download: 940.43 Mbps
                    [05.10.2022 17:25.13.833] [LOG]   [SPEED] Download: 940.66 Mbps
                    [05.10.2022 17:25.13.934] [LOG]   [SPEED] Download: 940.26 Mbps
                    [05.10.2022 17:25.14.034] [LOG]   [SPEED] Download: 940.80 Mbps
                    [05.10.2022 17:25.14.135] [LOG]   [SPEED] Download: 939.99 Mbps
                    [05.10.2022 17:25.14.235] [LOG]   [SPEED] Download: 941.33 Mbps
                    [05.10.2022 17:25.14.336] [LOG]   [SPEED] Download: 940.78 Mbps
                    [05.10.2022 17:25.14.437] [LOG]   [SPEED] Download: 940.89 Mbps
                    [05.10.2022 17:25.14.537] [LOG]   [SPEED] Download: 939.52 Mbps
                    [05.10.2022 17:25.14.638] [LOG]   [SPEED] Download: 941.53 Mbps
                    [05.10.2022 17:25.14.739] [LOG]   [SPEED] Download: 940.80 Mbps
                    [05.10.2022 17:25.14.839] [LOG]   [SPEED] Download: 941.01 Mbps
                    [05.10.2022 17:25.14.939] [LOG]   [SPEED] Download: 940.96 Mbps
                    [05.10.2022 17:25.14.973] [LOG]   [SPEED] Download: 940.70 Mbps
                    [05.10.2022 17:25.15.326] [LOG]   [SPEED] Upload: 571.68 Mbps
                    [05.10.2022 17:25.15.427] [LOG]   [SPEED] Upload: 596.83 Mbps
                    [05.10.2022 17:25.15.527] [LOG]   [SPEED] Upload: 615.15 Mbps
                    [05.10.2022 17:25.15.629] [LOG]   [SPEED] Upload: 624.40 Mbps
                    [05.10.2022 17:25.15.729] [LOG]   [SPEED] Upload: 631.77 Mbps
                    [05.10.2022 17:25.15.830] [LOG]   [SPEED] Upload: 636.47 Mbps
                    [05.10.2022 17:25.15.931] [LOG]   [SPEED] Upload: 640.61 Mbps
                    [05.10.2022 17:25.16.031] [LOG]   [SPEED] Upload: 644.16 Mbps
                    [05.10.2022 17:25.16.132] [LOG]   [SPEED] Upload: 646.54 Mbps
                    [05.10.2022 17:25.16.233] [LOG]   [SPEED] Upload: 648.11 Mbps
                    [05.10.2022 17:25.16.334] [LOG]   [SPEED] Upload: 650.32 Mbps
                    [05.10.2022 17:25.16.434] [LOG]   [SPEED] Upload: 647.69 Mbps
                    [05.10.2022 17:25.16.535] [LOG]   [SPEED] Upload: 649.62 Mbps
                    [05.10.2022 17:25.16.636] [LOG]   [SPEED] Upload: 648.94 Mbps
                    [05.10.2022 17:25.16.736] [LOG]   [SPEED] Upload: 649.55 Mbps
                    [05.10.2022 17:25.16.837] [LOG]   [SPEED] Upload: 650.22 Mbps
                    [05.10.2022 17:25.16.938] [LOG]   [SPEED] Upload: 651.65 Mbps
                    [05.10.2022 17:25.17.039] [LOG]   [SPEED] Upload: 652.29 Mbps
                    [05.10.2022 17:25.17.139] [LOG]   [SPEED] Upload: 655.27 Mbps
                    [05.10.2022 17:25.17.240] [LOG]   [SPEED] Upload: 657.43 Mbps
                    [05.10.2022 17:25.17.341] [LOG]   [SPEED] Upload: 658.04 Mbps
                    [05.10.2022 17:25.17.442] [LOG]   [SPEED] Upload: 658.68 Mbps
                    [05.10.2022 17:25.17.542] [LOG]   [SPEED] Upload: 667.05 Mbps
                    [05.10.2022 17:25.17.643] [LOG]   [SPEED] Upload: 667.09 Mbps
                    [05.10.2022 17:25.17.744] [LOG]   [SPEED] Upload: 667.35 Mbps
                    [05.10.2022 17:25.17.844] [LOG]   [SPEED] Upload: 667.49 Mbps
                    [05.10.2022 17:25.17.945] [LOG]   [SPEED] Upload: 666.08 Mbps
                    [05.10.2022 17:25.18.046] [LOG]   [SPEED] Upload: 665.42 Mbps
                    [05.10.2022 17:25.18.146] [LOG]   [SPEED] Upload: 665.49 Mbps
                    [05.10.2022 17:25.18.247] [LOG]   [SPEED] Upload: 665.38 Mbps
                    [05.10.2022 17:25.18.347] [LOG]   [SPEED] Upload: 666.88 Mbps
                    [05.10.2022 17:25.18.449] [LOG]   [SPEED] Upload: 667.77 Mbps
                    [05.10.2022 17:25.18.549] [LOG]   [SPEED] Upload: 668.95 Mbps
                    [05.10.2022 17:25.18.649] [LOG]   [SPEED] Upload: 669.30 Mbps
                    [05.10.2022 17:25.18.750] [LOG]   [SPEED] Upload: 669.47 Mbps
                    [05.10.2022 17:25.18.851] [LOG]   [SPEED] Upload: 669.47 Mbps
                    [05.10.2022 17:25.18.952] [LOG]   [SPEED] Upload: 669.74 Mbps
                    [05.10.2022 17:25.19.052] [LOG]   [SPEED] Upload: 669.76 Mbps
                    [05.10.2022 17:25.19.153] [LOG]   [SPEED] Upload: 668.45 Mbps
                    [05.10.2022 17:25.19.254] [LOG]   [SPEED] Upload: 668.17 Mbps
                    [05.10.2022 17:25.19.354] [LOG]   [SPEED] Upload: 666.30 Mbps
                    [05.10.2022 17:25.19.455] [LOG]   [SPEED] Upload: 664.88 Mbps
                    [05.10.2022 17:25.19.556] [LOG]   [SPEED] Upload: 663.21 Mbps
                    [05.10.2022 17:25.19.658] [LOG]   [SPEED] Upload: 663.05 Mbps
                    [05.10.2022 17:25.19.758] [LOG]   [SPEED] Upload: 662.47 Mbps
                    [05.10.2022 17:25.19.859] [LOG]   [SPEED] Upload: 662.36 Mbps
                    [05.10.2022 17:25.19.960] [LOG]   [SPEED] Upload: 661.67 Mbps
                    [05.10.2022 17:25.20.060] [LOG]   [SPEED] Upload: 662.10 Mbps
                    [05.10.2022 17:25.20.161] [LOG]   [SPEED] Upload: 662.88 Mbps
                    [05.10.2022 17:25.20.262] [LOG]   [SPEED] Upload: 663.91 Mbps
                    [05.10.2022 17:25.20.362] [LOG]   [SPEED] Upload: 664.68 Mbps
                    [05.10.2022 17:25.20.463] [LOG]   [SPEED] Upload: 664.89 Mbps
                    [05.10.2022 17:25.20.564] [LOG]   [SPEED] Upload: 664.85 Mbps
                    [05.10.2022 17:25.20.665] [LOG]   [SPEED] Upload: 665.50 Mbps
                    [05.10.2022 17:25.20.765] [LOG]   [SPEED] Upload: 665.55 Mbps
                    [05.10.2022 17:25.20.866] [LOG]   [SPEED] Upload: 665.73 Mbps
                    [05.10.2022 17:25.20.967] [LOG]   [SPEED] Upload: 665.68 Mbps
                    [05.10.2022 17:25.21.067] [LOG]   [SPEED] Upload: 664.60 Mbps
                    [05.10.2022 17:25.21.169] [LOG]   [SPEED] Upload: 666.06 Mbps
                    [05.10.2022 17:25.21.269] [LOG]   [SPEED] Upload: 666.48 Mbps
                    [05.10.2022 17:25.21.370] [LOG]   [SPEED] Upload: 666.63 Mbps
                    [05.10.2022 17:25.21.471] [LOG]   [SPEED] Upload: 666.78 Mbps
                    [05.10.2022 17:25.21.571] [LOG]   [SPEED] Upload: 666.96 Mbps
                    [05.10.2022 17:25.21.672] [LOG]   [SPEED] Upload: 666.07 Mbps
                    [05.10.2022 17:25.21.774] [LOG]   [SPEED] Upload: 665.40 Mbps
                    [05.10.2022 17:25.21.874] [LOG]   [SPEED] Upload: 665.38 Mbps
                    [05.10.2022 17:25.21.974] [LOG]   [SPEED] Upload: 665.46 Mbps
                    [05.10.2022 17:25.22.076] [LOG]   [SPEED] Upload: 665.60 Mbps
                    [05.10.2022 17:25.22.177] [LOG]   [SPEED] Upload: 665.71 Mbps
                    [05.10.2022 17:25.22.244] [LOG]   [SPEED] Upload: 665.87 Mbps
                    [05.10.2022 17:25.22.898] [LOG]   [SPEED] Result: {
                      timestamp: 2022-10-05T15:25:22.000Z,
                      ping: { jitter: 0.353, latency: 14.293 },
                      download: { bandwidth: 117587756, bytes: 958119880, elapsed: 8206 },
                      upload: { bandwidth: 83233466, bytes: 596812565, elapsed: 7211 },
                      packetLoss: 0,
                      isp: 'Free SAS',
                      interface: {
                        internalIp: '192.168.0.138',
                        macAddr: 'xx:xx:xx:xx:xx:x',
                        isVpn: false,
                        externalIp: 'xxx.xxx.xxx'
                      server: {
                        country: 'Belgium',
                        host: 'speedtest.arcadiz.net',
                        port: 8080,
                        ip: '185.160.128.145'
                      result: {
                        url: 'https://www.speedtest.net/result/c/82415bc5-9799-4ec2-949c-b1a69d1774a4'
                    [05.10.2022 17:25.22.899] [LOG]   [SPEED] Done
                    [05.10.2022 17:25.22.899] [LOG]   [SPEED] Update Programmed
                    I’m not a magician :)
                    I just follow speedtest v2.2.0 usage in the ReadMe file of this library.
                    Note: That you can see in debug: https://www.speedtest.net/result/c/82415bc5-9799-4ec2-949c-b1a69d1774a4 is the shared link of this speedtest
                    It’s the same like MM² return
                    S bheplerB 2 Replies Last reply Reply Quote 0
                      sdetweil @bugsounet
                      @bugsounet said in Internet Monitor:
                      the problem is under windows, this path is bad as it doesn’t have \
                      unfortunately NPM is NOT platform neutral
                      you can’t even do it with a .cmd (and bash script without .sh) in the current folder…
                      as windows would work, but then linux would fail as current folder not in the PATH
                      I wrote a js file that could be launched on either and launch the right thing
                      but a pain in the rear
                      bugsounetB 1 Reply Last reply Reply Quote 1
                        bugsounet Banned @sdetweil
                        That why i says :
                        I’m glad that you use windows 😧
                        Now retry with your pi, a linux env or … with wsl under windows 😉
                        • 10
                        • 11
                        • 10 / 11
