    MMM-WorldTides - show high and low water for your region
    12 Posts 5 Posters 8.1k Views 5 Watching
    • yawnsY Offline
      yawns Moderator
      Description:
      Since I was born in the north of Germany (Bremerhaven) and enjoy mudflat tours I wanted to generate a module showing high and low water. I tested it with some locations in Germany. This module derives predictions from worldtides.info for a given tide station
      Screenshots:
      Download:
      [card:yawnsde/MMM-WorldTides]
      Version 1.0.0
      • initial release
      1 Reply Last reply Reply Quote 3
      • O Offline
        onetwankyfive
        Is there a way to make it 12 hour instead of 24 hour time?
        yawnsY 1 Reply Last reply Reply Quote 0
        • yawnsY Offline
          yawns Moderator
          There should be. I use the time format which is set in config.js but I did not check. I simply forgot about that. I will check tomorrow evening and let you know what to do.
          • yawnsY Offline
            yawns Moderator @onetwankyfive
            @onetwankyfive said in MMM-WorldTides - show high and low water for your region:
            Hi, sorry it took a bit longer than expected to find some time. It actually used 12 hour format, I just forgot the “am/pm” extension.
            So I replaced this:
            time: ((this.config.timeFormat === 24) ? moment(t.dt, "X").format("HH:mm") : moment(t.dt, "X").format("hh:mm")),
            with this:
            time: ((this.config.timeFormat === 24) ? moment(t.dt, "X").format("HH:mm") : moment(t.dt, "X").format("hh:mm a")),
              A Former User
              Hmm… like the sound of the mod as live on the water, and would be handy, but git cloned repository and installed, added to config
              		module: 'MMM-WorldTides',
              		position: 'top_right',
              		longitude: '8.134', //longitude and latitude need to be written with . instead of ,
              		latitude: '98.299',
              		appid: 'APIKEY' //appid needs to be requested from worldtides.info
              And well getting the MM error … Any thoughts?
              bheplerB 1 Reply Last reply Reply Quote 0
              • bheplerB Offline
                bhepler Module Developer @Guest
                @wjdw87 Just based on what you quoted, you have not properly closed your config section. You’re missing a close bracket just after the API KEY value.
                	latitude: '98.299',
                  A Former User @bhepler
                  @bhepler Oops my bad, many thanks for spotting that @bhepler
                  Now to change those icons
                  • yawnsY Offline
                    yawns Moderator @Guest
                    @wjdw87
                    I moved the symbols to config section and updated the module on github
                    Just do a git pull in the MMM-WorldTides directory and afterwards you can define own css symbols (existing in weathericons or fontawesome) in your magic mirror config.js file
                    read.me was also updated to explain the change
                      A Former User
                      Many thanks, though i did update manually in the scripts yesterday, will look at options and update accordingly if the icons are more in line that are on offer, great mod.
                      BTW any plans to go more indepth with the feeds (tidal range, depth etc)?
                      • yawnsY Offline
                        @wjdw87
                        Currently not, although the API provides this information. Maybe I could add a switch to enable more information. It’s just a matter of space available on screen … and free time of course :-)
