    MMM-ModuleScheduler - Module Schedules and Notifications
    moduleschedulecronnotifications
    82 Posts 20 Posters 130.6k Views 20 Watching
    • I Offline
      ianperrin
      Description:
      A helper module for creating schedules which
      • Hide, show or dim individual modules, groups of modules or all modules
      • Send notifications to other modules (e.g. to restart/turn off your MagicMirror, turn on/off your screen, and turn off your Pi via MMM-Remote-Control
      As ever this is work in progress, so check out the ReadMe file for installation and configuration notes, keep your module updated and do report any issues.
      Screenshots:
      Add as many screenshots as you like.
      Example Scheduling
      Download:
      [card:ianperrin/MMM-ModuleScheduler]
      Change Log
      Version 1.4
      • Added global schedules which allow a single schedule to show/hide/dim all modules
      • Added group schedules which allow a single schedule to show/hide/dim a subset of modules
      • Added support for visibility locking introduced in Magic Mirror 2.1.0
      • Added debug config option to control output to logs
      Version 1.3
      • Added ability to schedule sending notifications to other modules
      Version 1.2
      • Added ability dim modules (instead of hiding them)
      Version 1.1.0
      • Added support for multiple schedules per module
      Version 1.0.1
      • Fixed issue with scheduled jobs when browser is refreshed
      Version 1.0.0
      • Initial version
      1 Reply Last reply Reply Quote 3
        cowboysdude Module Developer
        Awesome module!! The only thing I found it doesn’t work on is the clock…
        The clock doesn’t have a config section and if you add it the config won’t load…
        I 1 Reply Last reply Reply Quote 0
        • I Offline
          ianperrin @cowboysdude
          @cowboysdude said in MMM-ModuleScheduler:
          Can you post an example of your config for the clock with the scheduler options?
          The following works for me to show the clock at 5 past each hour and hide in again at quarter past the hour…
          	module: 'clock',
          	position: 'top_left',
          	classes: 'scheduler',
          		module_schedule: {from: '5 * * * *', to: '15 * * * *'},
            Well as it turns out… had an issue and had to use my img backup to reinstall the mirror… little did I know I had this already set up and working on the img so it does!!! :)
            • I Offline
              @cowboysdude Glad to hear it works!
                I must have had it setup wrong so that was my fault… like I said it’s working! Thank you!
                  Just curious would it be possible not to hide but to dim specific modules?
                  strawberry 3.141S I 2 Replies Last reply Reply Quote 0
                  • strawberry 3.141S Offline
                    strawberry 3.141 Project Sponsor Module Developer @cowboysdude
                    @cowboysdude adding a css filter to the specific module could set the brightness down
                    I 1 Reply Last reply Reply Quote 1
                    • I Offline
                      ianperrin @strawberry 3.141
                      @strawberry-3.141 said in MMM-ModuleScheduler:
                      Great idea - will give it a go ;)
                      • I Offline
                        I’ve pushed an update which includes the ability to dim a module. Please feel free to update the module and use the example configuration to test it out.
                        cowboysdudeC 1 Reply Last reply Reply Quote 2
                        • 1 / 9
