MMM-DarkSkyForecast - Yet ANOTHER weather module
@j-e-f-f Great module, definitely my favorite weather module so far!
2 things would make it perfect in my opinion: Feels like temperature and sunrise/sunset data.
Do you have any plans to add those in the future?
Thank You!
@j-e-f-f The best replacement for DarkSky that I’ve found is https://www.climacell.co/weather-api/ since its hyper-local. Free tier gets you 30,000 calls/month.
@drippyer said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
Just wanted to let folks know that DarkSky is no longer accepting new users to the API now that they have been acquired by Apple.
Maybe I shouldn’t say it, but… you can find many working DarkSky API codes around (that can be used simultaneously by more than one user).
Just do a proper search in Google Images and here you go. 😂
@michaelsfp said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
This one sounds really interesting! Thanks! Seems to have minutely data for Europe as well which is rare.
OpenWeatherMaps now introduced a new OneCall-API which is similar to the old DarkSky. There is even a table for migrating from DarkSky to OpenWeather. Maybe someone who has coding skills could see rebuild this lovely module? In the end Dark Sky API will be discontinued completely so everyone will need to look out for something else :)
@michael5r What is the command line that allows me to reduce the spaces in the “forescast” table?
cual es la linea de comando que me permite reducir los espacios en la tabla de “forescast”? -
I am having issue it says LOADING…
here is my config
module: “MMM-DarkSkyForecast”,
header: “Weather”,
position: “top_right”,
classes: “default everyone”,
disabled: false,
apikey: " from climacell*",
latitude: “45.582152”,
longitude: “-73.584595”,
iconset: “4c”,
concise: false,
forecastLayout: “table”
},please help :(
You can’t use a Climacell API key with MMM-DarkSkyForecast.
any other key I can use ?
