    Save performance when rotating screen e.g. on Raspberry Pi
    Scheduled Pinned Locked Moved Showcase
    19 Posts 11 Posters 19.5k Views 14 Watching
      sdetweil @hdez
      @hdez said in Save performance when rotating screen e.g. on Raspberry Pi:
      (sorry, I don’t know how to put this in a separate box
      after you paste the text, select it, and then push the button above the editor that looks like </>
      H 1 Reply Last reply Reply Quote 0
      • H Offline
        hdez @sdetweil
        @sdetweil Thanks. Next time.
        • H Offline
          hdez
          Never mind guys I was able to get it to work by following the instructions here
          After all it wasn’t the css file that I needed to change, but the Pi autostart file in the /etc/xdg/lxsession/LXDE-pi/ folder.
            Goeste
            Thank you @ptrk95, that just came in handy while playing around with fullpageos and the magic mirror in my docker setup!
              floydrexdime
              Hi there! thanks for the easy fix! Is there a way to reposition the modules on the mirror? when I rotate the screen 90 degrees the bottom module (the newsfeed) its completely cut out.
              • S sdetweil referenced this topic on
