    install MM2.18 on win10 pc
    22 Posts 2 Posters 6.6k Views 3 Watching
      Johans
      Re: Installing Magic mirror on windows 10
      Hi, trying to run MM on a win10 PC - followed the instructions from Mykle1
      but when I run npm start I get following message
      error MM.PNG image url)
      (I already removed DISPLAY… from Package.json)
      how to fix this?
        sdetweil @Johans
        @johans see this issue comment
        https://github.com/MichMich/MagicMirror/issues/2779#issuecomment-1011124060
        J 1 Reply Last reply Reply Quote 2
          Johans @sdetweil
          @sdetweil - thanks for the info. now it is working fine .
            Johans
            I got MM working under Win10 and most of the apps are working.
            but in the end I prefere more the linux, so I installed debian, git, nodejs, and MM.
            When to start the MM i get following message
            Although I updated the package.json file and corrected accoring the instructions, I still get an error message.
            What else is missing?
            S 3 Replies Last reply Reply Quote 0
              sdetweil @Johans
              @johans
              well, the output says that the \ wasn’t right as it removed all the slashes and made 1 big string…
              because u posted screenshots and not text I can’t show more
              what node/npm versions did u install ??
              npm -v
              node -v
              J 3 Replies Last reply Reply Quote 0
                Johans @sdetweil
                npm is version 8.5.2
                node = 17.7.2
                  Johans @sdetweil
                  @sdetweil said in install MM2.18 on win10 pc:
                  Do you want the content of the package.json file?
                  	"name": "magicmirror",
                  	"version": "2.18.0",
                  	"description": "The open source modular smart mirror platform.",
                  	"main": "js/electron.js",
                  	"scripts": {
                  		"start": "node_modules\\.bin\\electron js\\electron.js",
                  		"start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev",
                  		"server": "node ./serveronly",
                  		"install": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error",
                  		"install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error",
                  		"postinstall": "npm run install-fonts && echo \"MagicMirror installation finished successfully! \n\"",
                  		"test": "NODE_ENV=test jest -i --forceExit",
                  		"test:coverage": "NODE_ENV=test nyc --reporter=lcov --reporter=text jest -i --forceExit",
                  		"test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
                  		"test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
                  		"test:unit": "NODE_ENV=test jest --selectProjects unit -i --forceExit",
                  		"test:prettier": "prettier . --check",
                  		"test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --config .eslintrc.json",
                  		"test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
                  		"test:calendar": "node ./modules/default/calendar/debug.js",
                  		"config:check": "node js/check_config.js",
                  		"lint:prettier": "prettier . --write",
                  		"lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --config .eslintrc.json --fix",
                  		"lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
                  		"lint:staged": "pretty-quick --staged",
                  		"prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed."
                    Johans @sdetweil
                    I also installed MM on Ubuntu V20.4 and I have exactly the same message as I get on Debian.
                      sdetweil @Johans
                      @Johans is it the same node and npm?
                      we havent tested on node 17.
                      only node 14 and 16
                      J 1 Reply Last reply Reply Quote 0
                        Johans @sdetweil
                        @sdetweil On Ubuntu I used node 16.14.2 and npm 8.5.5 while on Debian I used node 17.7.2 and npm 8.5.2. And both seems to give me the same error message
                        • 1 / 3
