    install MM2.18 on win10 pc
    22 Posts 2 Posters 6.6k Views 3 Watching
      Johans @sdetweil
      @sdetweil I have the icon under windows and when I start, Ubuntu it starts with the user I created during installation. ubuntulogin.png
      So I guess this is my normal user?
      I installed node & MM from jstal@DESKTOP-HF7R0J9 As I think this is correct - or not?
        sdetweil @Johans
        @Johans wait. you are running Ubuntu in lsw?
        that’s text mode. electron won’t run there
        J 1 Reply Last reply Reply Quote 0
          Johans @sdetweil
          @sdetweil , yes lsw2 that is how I installed it. So that is not good? How do I then make a proper installation on a windows PC? Do you have a link-guide to follow?
            sdetweil @Johans
            @Johans open a cmd.exe window
            and then do the install steps
            but you said u did that already…
            but wanted linux
            for linux desktop on windows you have to use a virtual machine…
            now, you might be able to run server mode and use the windows browser to access
            in the lsw linux command prompt
            cd ~/MagicMirror
            npm run server
            then go to windows desktop and open browser
            http://localhost:8080
              Johans @sdetweil
              @sdetweil - using virtual machine - don’t have any expierience on that or how to activate.
              Let me do following: I clean up and remove the Ubuntu & Debian app I installed.
              Then I’m going to look up some youtube vids on how to install Ubuntu with virtual box or virtual machine active.
              I’ll come back later when that is done properly -
              thanks for your support so far.
              • 3 / 3
