Issue with PIR Sensor after upgrade to 2.19
Same…npm WARN deprecated [email protected]: this library is no longer supported npm WARN deprecated [email protected]: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. npm WARN deprecated [email protected]: request has been deprecated, see https://github.com/request/request/issues/3142 > [email protected] postinstall > node_modules/.bin/electron-rebuild -e ../../node_modules/electron ⠋ Searching dependency tree An unhandled error occurred inside electron-rebuild Could not detect abi for version 17.2.0 and runtime electron. Updating "node-abi" might help solve this issue if it is a new release of electron Error: Could not detect abi for version 17.2.0 and runtime electron. Updating "node-abi" might help solve this issue if it is a new release of electron at Object.getAbi (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-abi/index.js:36:9) at new Rebuilder (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:126:48) at rebuildWithOptions (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:404:23) at Object.doRebuild [as rebuild] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:427:16) at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/cli.js:124:33 at Generator.next (<anonymous>) at fulfilled (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/cli.js:6:58) npm ERR! code 255 npm ERR! path /home/pi/MagicMirror/modules/MMM-PIR-Sensor npm ERR! command failed npm ERR! command sh -c node_modules/.bin/electron-rebuild -e ../../node_modules/electron npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2022-04-07T15_08_23_853Z-debug-0.log
@OliWer ok, 2 more steps.
ok, we are executing electron rebuild from the module folderm, it can’t find the important info about electron in the base folder… SO
cd ~/MagicMirror npm install electron-rebuild --save
then cd to the module folder again and then
~/MagicMirror/node_modules/.bin/electron-rebuild
@karsten13 yeh, he just said he wasn’t gonna fix his tool…
@sdetweil AFAIS someone got it running https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more/32?page=4# but don’t know if it works
@karsten13 magicmirror-rebuild does not work for this module…and won’t be fixed
(as the module is ‘archived’) -
yes, MMM-PIR-Sensor is deprecated so its better to use another module which is still maintained.
I got MMM-PIR-Sensor installed with this workaround:
Change dependencies section in
package.json
to"dependencies": { "onoff": "latest", "magicmirror-rebuild": "latest" }
Run
npm install
which will fail.Edit
node_modules/epoll/binding.gyp
and insert the following in line 2 (after the first{
):"variables": { "openssl_fips" : "0" },
Run
npm install
again. -
Thanks for your help =)
I was not able to get MMM-PIR-Sensor running, even with your steps listed above. As it is deprecated I did what @karsten13 suggested and used another PIR (MMM-PIR). It had the same issue first, but using magicmirror-rebuild from https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more?page=1 I was able to got the PIR working again.
So again: Thanks for trying to help and your suggestions!
