    Need help with refactoring charting for a fork of a module.
    16 Posts 2 Posters 2.4k Views 2 Watching
      jwilson5607
      So I wanted to get MMM-BeeStat working, since its out of date and the module has not been updated to the latest api calls. I appear to have gotten the API configured right, but I am unsure if I am actually pulling the data down right and how to parse the data. This is partly due to the fact I am unsure how the data was presented in the past so I cannot really compare before and after json results from the call and partly due to the fact I am a complete NOOB when it comes to javascript.
      If I need to reformat this, or add/remove info or provide more context - please let me know
      'use strict';
      Module.register("MMM-Beestat", {
          hist: [],
          // Default module config.
          defaults: {
              updateInterval: 360 * 60 * 1000, // every 6 hours
              url: 'https://api.beestat.io/?api_key=',
              api_key: "", //request it from beestat
              thermostat_id: 0, //via &resource=ecobee_thermostat&method=read_id
              time_period: "month",
              time_count: 3,
              width: 300,
              height: 200,
              fadeSpeed: 2000,
              chart_title: "Last 3 months runtime"
          getStyles: function() {
              return ["MMM-Beestat.css"];
          getScripts: function() {
              return ["modules/" + this.name + "/node_modules/chart.js/dist/Chart.bundle.min.js"];
          start: function() {
              this.loaded_history = false;
              this.getData();
              this.scheduleUpdate();
          // Override dom generator.
          getDom: function() {
              const outerWrapper = document.createElement("beestat");
              const demandWrapper = document.createElement("div");
              const chartWrapper = document.createElement("div");
              chartWrapper.setAttribute("style", "position: relative; display: inline-block;");
              if (!this.loaded_history) {
                  outerWrapper.innerHTML = this.translate("LOADING");
                  outerWrapper.className = "dimmed light small";
                  return outerWrapper;
              demandWrapper.className = 'medium bright';
              if (this.hist) {
                  // Create chart canvas
                  const chartCanvas  = document.createElement("canvas");
                  var arrHeat = [];
                  var arrCool = [];
                  var arrLabels = []; //later set to blanks so the graph plots the points
                  for (var i = 0; i < this.hist.data.length; i++) {
                      var heatRuntime = 0;
                      var coolRuntime = 0;
                      //heat
                      if (this.hist.data[i].auxiliary_heat_1 > 0) {
                          heatRuntime += this.hist.data[i].sum.auxiliary_heat_1 / 3600;
                      if (this.hist.data[i].auxiliary_heat_2 > 0) {
                          heatRuntime += this.hist.data[i].sum.auxiliary_heat_2 / 3600;
                      if (this.hist.data[i].auxiliary_heat_3 > 0) {
                          heatRuntime += this.hist.data[i].sum.auxiliary_heat_3 / 3600;
                      if (this.hist.data[i].compressor_heat_1 > 0) {
                          heatRuntime += this.hist.data[i].sum.compressor_heat_1 / 3600;
                      if (this.hist.data[i].compressor_heat_2 > 0) {
                          heatRuntime += this.hist.data[i].sum.compressor_heat_2 / 3600;
                      //cool
                      if (this.hist.data[i].compressor_cool_1 > 0) {
                          coolRuntime += this.hist.data[i].sum.compressor_cool_1 / 3600;
                      if (this.hist.data[i].compressor_cool_2 > 0) {
                          coolRuntime += this.hist.data[i].sum.compressor_cool_2 / 3600;
                      if (heatRuntime > 0) {
                          arrHeat.push(heatRuntime);
                      } else {
                          arrHeat.push(0);
                      if (coolRuntime > 0) {
                          arrCool.push(coolRuntime);
                      } else {
                          arrCool.push(0);
                      arrLabels.push('');
                  var chartconfig = {
                      type: 'bar',
                      data: {
                          labels: arrLabels,
                          datasets: [{
                              backgroundColor: "#fd9644",
                              data: arrHeat
                              backgroundColor: "#45aaf2",
                              data: arrCool
                      options: {
                          scales: { xAxes: [{ stacked: true }], yAxes: [{ stacked: true }] },
                          elements: { point: { radius: 0 } },
                          legend: { display: false },
                          title: { display: true, text: this.config.chart_title, padding: 5 }
                  this.chart = new Chart(chartCanvas.getContext("2d"), chartconfig);
                  chartCanvas.width  = this.config.width;
                  chartCanvas.height = this.config.height;
                  chartCanvas.setAttribute("style", "width: " + this.config.width + "; height: " + this.config.height+";");
                  // Append chart
                  chartWrapper.appendChild(chartCanvas);
                  outerWrapper.appendChild(demandWrapper);
                  outerWrapper.appendChild(chartWrapper);
          scheduleUpdate: function(delay) {
              var nextLoad = this.config.updateInterval;
              if (typeof delay !== "undefined" && delay >= 0) {
                  nextLoad = delay;
              var self = this;
              setInterval(function() {
                  self.getData();
              }, nextLoad);
          getData: function () {
              var url = this.config.url + this.config.api_key + '&resource=runtime_thermostat_summary&method=read_id&arguments={"attributes":{"thermostat_id":'+this.thermostat_id+',"date":{"value":"-'+this.time_count+''+this.time_period+'","operator":">"}}}';
              this.sendSocketNotification('beestat_runtime', url);
          socketNotificationReceived: function(notification, payload) {
              if (notification === "beestat_runtime") {
                  this.hist = payload;
                  this.loaded_history = true;
              //display only when data is loaded
              if (this.loaded_history) {
                  this.updateDom(this.config.fadeSpeed);
      Sample results from postman:
      "success": true,
          "data": {
              "29249277": {
                  "runtime_thermostat_summary_id": 29249277,
                  "user_id": 18261,
                  "thermostat_id": XXXXXX,
                  "date": "2022-03-07",
                  "count": 124,
                  "sum_compressor_cool_1": 0,
                  "sum_compressor_cool_2": 0,
                  "sum_compressor_heat_1": 0,
                  "sum_compressor_heat_2": 0,
                  "sum_auxiliary_heat_1": 3600,
                  "sum_auxiliary_heat_2": 1335,
                  "sum_fan": 8070,
                  "sum_humidifier": 15,
                  "sum_dehumidifier": 0,
                  "sum_ventilator": 0,
                  "sum_economizer": 0,
                  "sum_degree_days": 0,
                  "avg_outdoor_temperature": 33.5,
                  "avg_outdoor_humidity": 83,
                  "min_outdoor_temperature": 31.4,
                  "max_outdoor_temperature": 36.3,
                  "avg_indoor_temperature": 68.4,
                  "avg_indoor_humidity": 38,
                  "deleted": false
              "29249278": {
                  "runtime_thermostat_summary_id": 29249278,
                  "user_id": 18261,
                  "date": "2022-03-08",
                  "count": 287,
                  "sum_auxiliary_heat_1": 11250,
                  "sum_auxiliary_heat_2": 0,
                  "sum_fan": 18150,
                  "sum_humidifier": 5010,
                  "avg_outdoor_temperature": 32,
                  "avg_outdoor_humidity": 75,
                  "min_outdoor_temperature": 27.1,
                  "max_outdoor_temperature": 36.5,
                  "avg_indoor_temperature": 68.2,
                  "avg_indoor_humidity": 36,
                  "deleted": false
        sdetweil @jwilson5607
        @jwilson5607 said in Need help with refactoring charting for a fork of a module.:
        .auxiliary_heat_1
        many of the fields do not exist in the data u showed
        does exist
        simularly
        does not exist
        but
        .sum_auxiliary_heat_2
        does exist
        sum. in the posted code implies there was a sub structure for those elements, but that sum .sum. structure isn’t there
        J 1 Reply Last reply Reply Quote 0
          jwilson5607 @sdetweil
          @sdetweil, thank you. I thought I had copied the right code (it was a late night). Here is what is in my code currently:
           //heat
                          if (this.hist.data[i].sum_auxiliary_heat_1 > 0) {
                              heatRuntime += this.hist.data[i].sum_auxiliary_heat_1 / 3600;
                          if (this.hist.data[i].sum_auxiliary_heat_2 > 0) {
                              heatRuntime += this.hist.data[i].sum_auxiliary_heat_2 / 3600;
                          if (this.hist.data[i].sum_auxiliary_heat_3 > 0) {
                              heatRuntime += this.hist.data[i].sum_auxiliary_heat_3 / 3600;
                          if (this.hist.data[i].sum_compressor_heat_1 > 0) {
                              heatRuntime += this.hist.data[i].sum_compressor_heat_1 / 3600;
                          if (this.hist.data[i].sum_compressor_heat_2 > 0) {
                              heatRuntime += this.hist.data[i].sum_compressor_heat_2 / 3600;
                          //cool
                          if (this.hist.data[i].sum_compressor_cool_1 > 0) {
                              coolRuntime += this.hist.data[i].sum_compressor_cool_1 / 3600;
                          if (this.hist.data[i].sum_compressor_cool_2 > 0) {
                              coolRuntime += this.hist.data[i].sum_compressor_cool_2 / 3600;
          Since I am using the same data set as the results from postman (results via the API call), I SHOULD get something - i THINK. However, I don’t see it loading the screen at all, and nothing showing that it crashed or something similar. My fork is found here if that makes looking at it easier: https://github.com/JWilson5607/MMM-Beestat
            @jwilson5607 open the developer window, ctrl-shift-i, select the sources tab and find your module and filename I the left nav.
            put a stop (click line number) on the code you just posted, and Ctrl to reload the page. code will stop there and u can examine the data structures,
            just mouse over the words …
              @sdetweil was able to get it tracked down to requesting:https://api.beestat.io/?api_key=0f3499eeb0f984dfdff55f8dd7c23eb4fbdee6b2&resource=runtime_thermostat_summary&method=read_id&arguments={“attributes”:{“thermostat_id”:undefined,“date”:{“value”:“-undefinedundefined”,“operator”:“>”}}}
              So I am now diving into that section. This is equal parts frustrating and elating. Thank you for pointing me in the directions you have.
                @jwilson5607 glad u are making progress
                  @sdetweil I’m packing it in for a day or two, give my brain a moment to relax. I verified I am getting in my URL properly (via output to the logs and that I am getting in a 200 response code via the console logs as well. However, its not parsing the data into the chart, and thats the part I was hoping would work with the sum_xxx_xxxx I added to match the json results from the GET call. If you have any ideas or places to look to understand it better as to why its failing, I would certainly appreciate it, if not - I do appreciate all the suggestions thus far.
                    @jwilson5607 i forked the repo…
                    so THIS will drive you NUTS…
                    I don’t have a good api key yet
                    the api doesn’t return an error if there is an error… it returns 200 (good)
                    and THEN u have to check the results for the actual status…
                    sloppy
                    MMM-Beestat: request response error=null statusCode=200
                    [05.05.2022 08:05.20.470] [LOG]   {
                      "statusCode": 200,
                       // my comment   see status is 200 (good)
                      // but body.success=false, and body.data .error_message="API key is invalid.",
                    // BUT it 'is' JSON, so the parse is successful...  just not any data u are expecting
                      "body": "{\"success\":false,\"data\":{\"error_message\":\"API key is invalid.\",\"error_code\":1003}}",
                      "headers": {
                        "date": "Thu, 05 May 2022 13:05:20 GMT",
                        "server": "Apache/2.4.29 (Ubuntu)",
                        "vary": "Accept-Encoding",
                        "content-length": "82",
                        "connection": "close",
                        "content-type": "application/json; charset=UTF-8"
                      "request": {
                        "uri": {
                          "protocol": "https:",
                          "slashes": true,
                          "auth": null,
                          "host": "api.beestat.io",
                          "port": 443,
                          "hostname": "api.beestat.io",
                          "hash": null,
                          "search": "?api_key=12345667&resource=runtime_thermostat_summary&method=read_id&arguments=%7B%22attributes%22:%7B%22thermostat_id%22:0,%22date%22:%7B%22value%22:%22-3%20month%22,%22operator%22:%22%3E%22%7D%7D%7D",
                          "query": "api_key=12345667&resource=runtime_thermostat_summary&method=read_id&arguments=%7B%22attributes%22:%7B%22thermostat_id%22:0,%22date%22:%7B%22value%22:%22-3%20month%22,%22operator%22:%22%3E%22%7D%7D%7D",
                          "pathname": "/",
                          "path": "/?api_key=12345667&resource=runtime_thermostat_summary&method=read_id&arguments=%7B%22attributes%22:%7B%22thermostat_id%22:0,%22date%22:%7B%22value%22:%22-3%20month%22,%22operator%22:%22%3E%22%7D%7D%7D",
                          "href": "https://api.beestat.io/?api_key=12345667&resource=runtime_thermostat_summary&method=read_id&arguments=%7B%22attributes%22:%7B%22thermostat_id%22:0,%22date%22:%7B%22value%22:%22-3%20month%22,%22operator%22:%22%3E%22%7D%7D%7D"
                        "method": "GET",
                        "headers": {}
                    I changed your request like this in node_helper to get this info on the console
                    request({ url: url, method: 'GET' }, function (error, response, body) {
                            console.log(self.name+": request response error="+JSON.parse(error)+" statusCode="+response.statusCode)
                              if (!error && response.statusCode == 200) {
                                console.log(JSON.stringify(response,null,2) );
                                var result = JSON.parse(body);
                                  self.sendSocketNotification(notification, result);
                              } else {
                                  console.log("MMM-Beestat : Could not load data. error="+JSON.stringify(error));
                    and then i looked in the dev console just to see
                    Screenshot at 2022-05-05 08-12-44.pngi
                      @jwilson5607 i changed the node_helper like this … I sent a pull request
                      accept it and this will be added to your instance, then on pi, git pull to get that update locally
                      restart magic mirror
                        getData: function (notification, url) {
                            var self = this;
                            console.log('requesting:' + url);
                              console.log(self.name+": request response="+JSON.parse(error)+" statusCode="+response.statusCode)
                                  console.log(JSON.stringify(result,null,2) );
                                  if(result.success==='true'){
                                    self.sendSocketNotification(notification, result.data);
                                  } else {
                                    console.log(self.name +" api request failed =>"+ result.data.error_message)
                                } else {
                        @sdetweil I see the data flowing into the logs now (I think it would be ok to comment out the console.log portion of this later on when I start parsing longer stretches of time). Thank you so much for looking at this! However, its now changing the title of the chart to Ecobee Runtime, and just sticking on loading… in the chart area. Screenshot 2022-05-06 210416.png
                        I don’t see any reference in the mmm-beestat.js file that should put this there for the title. I have chart_title defined in the code and called via this snippet here on 118:
                        It also never displays the data. I use PowerShell for my day to day scripting work (IAM Systems Engineer) and Javascript is a whole new beast to me (one I am having difficulty adjusting to working with), but I know order of operations can be important. My guess is that it is not in this case, but unsure.
                        I THINK its related to the getdata function and specifically how its treating the socketNotificationReceived potion of this.
                                var url = this.config.url + this.config.api_key + '&resource=ecobee_runtime_thermostat&method=get_aggregate_runtime&arguments={"ecobee_thermostat_id":'+this.config.ecobee_thermostat_id+',"time_period":"'+this.config.time_period+'","time_count":'+this.config.time_count+',"group_by":"'+this.config.group_by+'"}';
                        Is this good or should it be different here? I see the original code is referencing in the node_helper file:
                        And you updated it to result.data… In the received section it references payload. Would changing this to result be whats needed here?
                        Let me reiterate again how much I appreciate your patience and assistance.
                        S 3 Replies Last reply Reply Quote 0
