    A few CalExt3 questions: background images, glance, and symbols
    10 Posts 4 Posters 2.5k Views 4 Watching
      almightyyoshi
      Re: MMM-CalendarExt3
      I’m feeling particularly dense, but can anyone answer these questions?
      1. Can cells (month view) have background images? If so, how? I like to set them for holidays and such.
      2. How do you use glance and step to “flip” to the next month? (I did this in CalExt2 using scenes and views) Do I need another instance of the default Calendar and CalExt3?
      3. When I try to use symbols other than the default symbol (changed in default Calendar config), my events don’t load in CalExt3 (or, oddly enough, the only events that load are from the only calendar I pull from Outlook…the rest are Google and don’t populate). I’ve checked the default Calendar module, and the new symbols are displayed there. Any ideas?
        MMRIZE @almightyyoshi
        @almightyyoshi
        1.
        .CX3 .month_6.date_16 {
          background-image: url("https://img.freepik.com/free-vector/flat-corpus-christi-illustration_23-2148934727.jpg?w=400");
          background-position: center center;
          background-size: cover;
          background-repeat: no-repeat;
        1. You need any “Commandable” module like MMM-Touch for touchscreen or MMM-GroveGestures for gesture sensor or MMM-RemoteControl or MMM-GoogleAssistant or any module which can emit custom notifications by your intentional condition.
        2. Show me your config. which symbol were you trying? With default symbol everything was ok?
        A B G 3 Replies Last reply Reply Quote 0
          almightyyoshi @MMRIZE
          @MMRIZE
          1. Thanks! I was so close. I thought I had to specify .cell. Also, I had completely forgotten to make an images folder, but that only took me 10 minutes to remember. :beaming_face_with_smiling_eyes:
          2. Thanks. I’ll look at MMM-Touch.
          3. Here’s my code. Yes, default works fine. It only messes up when I try to specify an icon.
          Default Calendar
                                  module: "calendar",
                                  //position: "bottom_center",
                                          colored: true,
                                          broadcastPastEvents: true,
                                          calendars: [
                                                  url: ...
                                                  color: "#3061E3",
                                                  auth: {
                                                        user: ...,
                                                        pass: ...
                                                  url: ...
                                                  color: "#DA2528",
                                                  auth: {
                                                        user: ...,
                                                        pass:  ...
                                                  url: ...
                                                  color: "#d2cf2a",
                                                  auth: {
                                                        user: ...,
                                                        pass: ...
                                                  url:
                                                  color: "#a716b8",
                                                  auth: {
                                                        user: ...,
                                                        pass: ...
                                                  url: ...
                                                  symbol: "fa-solid fa-cake-candles",
                                                  auth: {
                                                        user: ...,,
                                                        pass: ...
                                                  url: ...
                                                  symbol: "fa-solid fa-music",
                                                  auth: {
                                                        user: ...,
                                                        pass: ...
          CalExt3
                      module: "MMM-CalendarExt3",
                      position: "middle_center",
                              mode: "month",
                              instanceID: "currentMonth",
                              firstDayOfWeek: 0,
                              useSymbol: true,
                              calendarSet: [],
            blouzbee @MMRIZE
            @MMRIZE
            your example works as you posted it. but if i want to target a local file as a background image for a specfic day. i cant get it to work. any HTTPS: i use works fine. i feel ive tried every variation i could find online. What’s the proper way to do that in calext3? thank you.
              MMRIZE @blouzbee
              @blouzbee
              I’ll assume your target local file would locate in
              ~/MagicMirror/modules/MMM-CalendarExt3/resources/target.png
              AND you might run your MM on localhost like this;
              http://localhost:8080
              Then, you can access like below;
              background-image: url("/modules/MMM-CalendarExt3/resources/target.png");
              OR
              background-image: url("http://localhost:8080/modules/MMM-CalendarExt3/resources/target.png");
              B 1 Reply Last reply Reply Quote 0
                blouzbee @MMRIZE
                @MMRIZE
                works! my syntax was correct. i think having the folder of .jpgs outside the MMM-CalendarExt3 folder was why it wasn’t working.
                How would I target cells for holidays that don’t fall on the same day every year? Is there a way to target the 328th day of the year?
                again thank you very much.
                  MMRIZE @blouzbee
                  @blouzbee
                  DayOfYear is not supported yet, but I’ll consider it in the future version.
                  • G Offline
                    greedyvegan @MMRIZE
                    @MMRIZE said in A few CalExt3 questions: background images, glance, and symbols:
                    Can I use this to add a background image to every date/square with “background-repeat” as a default and override it for specific dates?
                      MMRIZE @greedyvegan
                      @greedyvegan
                      Of course, you may need some adjusting size and position, anyway, its possible.
                      /* In your css/custom.css */
                      .CX3 .cell {
                        background-image: url("https://forum.magicmirror.builders/assets/uploads/files/1708912838487-calendar-background.001.png");
                        background-position: top left;
                      .CX3 .cell.today {
                        background-image: url("https://picsum.photos/200?1");
                      .CX3 .cell.month_2.date_28 {
                        background-image: url("https://picsum.photos/200?2");
                      .CX3 .cell.month_3 {
                        background-image: url("https://picsum.photos/200?3");
                      You can also use other prepred selectors like thisWeek, thisMonth, thisYear, year_2025, weekday_3, and its combination.
                      And this method was by the static date.
                      If you want to change the background of the specific cell dynamically by the event, See the cell manipulation parts in README.
                      G 1 Reply Last reply Reply Quote 0
                      • G Offline
                        greedyvegan @MMRIZE
                        @MMRIZE
                        thank you very much
