    MMM-Fitbit2
    Scheduled Pinned Locked Moved Health
    fitbithealthfitnesshealthywaterfoodtrackingactivity tracker
    98 Posts 21 Posters 116.0k Views 19 Watching
      sdetweil @richmp95
      @richmp95 you’d have to post in an issue in the module GitHub repo
      • V Offline
        Vizulize Module Developer @richmp95
        @richmp95 - last I checked, this still works. Why does it need ‘reviving’?
        If you would like to have extra features, I am open to suggestions and contributions.
        R 1 Reply Last reply Reply Quote 0
        • L Offline
          Layton
          Is there anyway to remove the goal tracking widget underneath each resource?
          I have been trying to play around with removing it myself, but every time I touch something it breaks the whole module.
          Any ideas!?
          V 1 Reply Last reply Reply Quote 0
          • V Offline
            Vizulize Module Developer @Layton
            @Layton
            I haven’t tried this and I haven’t looked at the code in a while, but I think you can just comment out this line to hide the progress bars:
            https://github.com/m-roberts/MMM-Fitbit2/blob/430d35056ceecfe612476a7d0307903b376ed6c0/MMM-Fitbit2.js#L242
            L 1 Reply Last reply Reply Quote 0
            • L Offline
              Layton @Vizulize
              @Vizulize That worked! Thank you :)
                richmp95 @Vizulize
                @Vizulize i am still having issues with this module. all it says is loading. any help with this i would appreciate it
                • V Offline
                  @richmp95 I’m afraid I can’t do much to help without error logs.
                  • MeidlmarkusM Offline
                    Meidlmarkus
                    Hi, updated MM and now Google-Fit can no longer be installed, so I gave MMM-Fitbit2 a go.
                    Thanks @Vizulize for your work, I’d really like to get it running.
                    I have the same error that is reported in the github:
                    npm ERR! must provide string spec
                    To reproduce, just try to install it on an updated MM system.
                    It happens when calling ./init.sh as per your instructions on github
                    Have you/has anybody figured out a way to initialize the module?
                    Markus
                      sdetweil @Meidlmarkus
                      @Meidlmarkus said in MMM-Fitbit2:
                      MMM-Fitbit2
                      remove these lines from package.json
                            "Requires this version to work",
                            "https://github.com/SVendittelli/MMM-fitbit/issues/23#issuecomment-464319931"
                        Meidlmarkus
                        Thanks, Sam!
                        Had it googled in the meantime, had renamed the package-lock.json und run npm init
                        It braught no further error, I called auth.sh and that’s where I’m stuck now.
                        After entering the credentials, no browser dialog opens and I’m not quite sure where to search it.
                        Am logged in over ssh and in addition have a browser open to :8080
                        Neither on the mirror, nor on the pc, there is any dialog appearing.
                        I guess I’ll start from scratch, remove the module folder, clone new from git, and try your suggested method with the original package.json?
                        Thanks again
                        Markus
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 9 / 10
