    MMM-NewsFeed multiple instances
    Scheduled Pinned Locked Moved General Discussion
    12 Posts 3 Posters 819 Views 3 Watching
    • E Offline
      Egnos
      Hello everybody,
      I am trying to duplicate the MMM-NewsFeed module because I would like to call it twice from the MMM-Pages module.
      The guides on the forum have had no effect, the module is not loaded.
      Can you help me?
      Thanks as always.
      My Mirror https://forum.magicmirror.builders/topic/17262/the-raspimirror-was-born/7
        sdetweil @Egnos
        @Egnos this module does not support multiple instances
        you can try to use the copy approach
        copy the MMM-Newsfeed module folder
        to another named folder in the module directory, MMM-Newsfeed2 for example
        in the new folder, rename the MMM-Newsfeed.js to match the new folder name. MMM-Newsfeed2.js
        edit that file and change the module.register(
        to use the new folder name
        in all cases the new name must match exactly as the system is case sensitive.
        then in config.js use the new folder name for module:
        E 1 Reply Last reply Reply Quote 0
        • E Offline
          Egnos @sdetweil
          I have already tried your advice but it didn’t work.
          The strange thing is that if I launch the two modules together, only MMM-NewsFeed starts.
          If I start them individually then the MMM-NewsFeed2 works too.
          When launched together, MMM-NewsFeed always prevails, not allowing the execution of MMM-NewsFeed2.
          daniele@raspberry:~/MagicMirror $ npm start
          > [email protected] start
          > ./run-start.sh $1
          [15.09.2022 13:57.13.128] [LOG] Starting MagicMirror: v2.20.0
          [15.09.2022 13:57.13.132] [LOG] Loading config ...
          [15.09.2022 13:57.13.135] [LOG] Loading module helpers ...
          [15.09.2022 13:57.13.137] [LOG] No helper found for module: alert.
          [15.09.2022 13:57.13.148] [LOG] Initializing new module helper ...
          [15.09.2022 13:57.13.148] [LOG] Module helper loaded: updatenotification
          [15.09.2022 13:57.13.149] [LOG] No helper found for module: clock.
          [15.09.2022 13:57.13.379] [LOG] Initializing new module helper ...
          [15.09.2022 13:57.13.379] [LOG] Module helper loaded: MMM-SystemStats
          [15.09.2022 13:57.13.427] [LOG] Initializing new module helper ...
          [15.09.2022 13:57.13.427] [LOG] Module helper loaded: MMM-NewsFeed
          [15.09.2022 13:57.13.437] [LOG] Initializing new module helper ...
          [15.09.2022 13:57.13.437] [LOG] Module helper loaded: MMM-NewsFeed2
          [15.09.2022 13:57.13.438] [LOG] All module helpers loaded.
          [15.09.2022 13:57.13.491] [LOG] Starting server on port 8080 ...
          [15.09.2022 13:57.13.501] [LOG] Server started ...
          [15.09.2022 13:57.13.502] [LOG] Connecting socket for: updatenotification
          [15.09.2022 13:57.13.502] [LOG] Starting module helper: updatenotification
          [15.09.2022 13:57.13.503] [LOG] Connecting socket for: MMM-SystemStats
          [15.09.2022 13:57.13.503] [LOG] Connecting socket for: MMM-NewsFeed
          [15.09.2022 13:57.13.504] [LOG] [FEED] MMM-NewsFeed Version: 1.2.0
          [15.09.2022 13:57.13.505] [LOG] Connecting socket for: MMM-NewsFeed2
          [15.09.2022 13:57.13.506] [LOG] [FEED] MMM-NewsFeed Version: 1.2.0
          [15.09.2022 13:57.13.507] [LOG] Sockets connected & modules started ...
          Ready to go! Please point your browser to: http://localhost:8080
          Starting chromium browser now, have patience, it takes a minute
          [15.09.2022 13:57.16.780] [INFO]  Checking git for module: MMM-SystemStats
          [15.09.2022 13:57.16.835] [INFO]  Checking git for module: MMM-NewsFeed
          [15.09.2022 13:57.16.850] [INFO]  Checking git for module: MMM-NewsFeed2
          [15.09.2022 13:57.16.865] [INFO]  Checking git for module: default
          [15.09.2022 13:57.23.546] [LOG]   [FEED] MMM-NewsFeed est now initialized!
          [15.09.2022 13:57.23.910] [LOG]   [FEED] MMM-NewsFeed est now initialized!
          • E Offline
            Egnos
            I realized that the two instances overlap, regardless of the position given in the configuration.
            both modules work (MMM-NewsFeed and MMM-NewsFeed2) but “cover” each other …
              sdetweil @Egnos
              @Egnos then you would have to have to fiddle with CSS
              so would have to rename the css file and change the response to getStyles to the new name…
              THEN you could use custom.css to attempt to fix
              as I said, you could ‘try’ the rename approach… sometimes not so easy…
              • E Offline
                Egnos @sdetweil
                @sdetweil said in MMM-NewsFeed multiple instances:
                Below the “MMM-NewsFeed2.css” file contained in the module but I can’t find "getStyles ":
                /* Magic Mirror
                 * Module: NewsFeed
                 * By @bugsounet -- Dupont Cédric <[email protected]>
                 * MIT Licensed.
                #NEWSFEED_CONTENER {
                  line-height:1.1em;
                  width: 100%;
                #NEWSFEED_CONTENER.showArticle {
                  opacity: 1;
                  transition: opacity 1s linear;
                #NEWSFEED_CONTENER.hideArticle {
                  opacity: 0;
                #NEWSFEED_TITLE {
                  margin-left: auto;
                  margin-right: auto;
                  white-space: nowrap;
                  overflow: hidden;
                  text-overflow: ellipsis;
                #NEWSFEED_ARTICLE {
                  font-size: 90%;
                  display: flex;
                #NEWSFEED_CONTENT {
                  padding: 10px;
                  margin-top: 1px;
                  font-size: 70%;
                  text-align: left;
                  height: 80px;
                  display: flex;
                #NEWSFEED_IMAGE {
                  margin-right: 10px;
                  float: left;
                  max-width: 10vw;
                  max-height: 10vh;
                  text-align: left;
                #NEWSFEED_DESCRIPTION {
                  opacity: 0;
                  line-height: 25px;
                  text-align: justify;
                  overflow: hidden;
                  display: -webkit-box;
                  -webkit-line-clamp: 3;
                  -webkit-box-orient: vertical;
                #NEWSFEED_DESCRIPTION.showArticle {
                  animation: 3s ease 0s normal forwards 1 fadein;
                @keyframes fadein{
                  0%   { opacity:0; }
                  66%  { opacity:0; }
                  100% { opacity:1; }
                #NEWSFEED_DESCRIPTION.hideArticle {
                  opacity: 1;
                  animation: none;
                #NEWSFEED_FOOTER {
                  text-align:right;
                #NEWSFEED_LOGO {
                  font-size: 100%;
                  font-weight: bold;
                  display: flex;
                #NEWSFEED_LOGO_PARTA {
                  margin-left: 10px;
                #NEWSFEED_LOGO_PARTB {
                  margin-right: 10px;
                #NEWSFEED_SOURCE {
                  margin-right: 8px;
                  font-weight: bold;
                  margin-top: -9px;
                  margin-bottom: 5px;
                  text-align: left;
                #NEWSFEED_SOURCE.start {
                  animation-duration: .8s;
                  animation-name: clignoter;
                  animation-iteration-count: 2;
                  transition: none;
                  animation-delay: 1s;
                #NEWSFEED_SOURCE.stop {
                  animation-name: stopclignoter;
                  animation-iteration-count: 1;
                @keyframes clignoter {
                  0%   { opacity:1; }
                  40%  { opacity:0; }
                  100% { opacity:1; }
                @keyframes stopclignoter {
                  0%   { opacity:1; }
                #NEWSFEED_TIME {
                  font-size: 50%;
                  text-align: right;
                  display: inline-block;
                  margin-right: 10px;
                  margin-top: 10px;
                  margin-bottom: -5px;
                #NEWSFEED_INFO {
                  width: 100%;
                  height: 110px;
                #NEWSFEED_QRCODE {
                  height: 120px;
                  width: 120px;
                  margin-top: 0px;
                  margin-right: -10px;
                  margin-left: 5px;
                /** Vertical **/
                #NEWSFEED_TITLE.vertical {
                  display: none;
                #NEWSFEED_CONTENT.vertical {
                  font-size: 80%;
                #NEWSFEED_IMAGE.vertical {
                  float: unset;
                  display: block;
                  margin-left: auto;
                  margin-right: auto;
                  max-width: 20vw;
                  max-height: 20vh;
                #NEWSFEED_SOURCE.vertical {
                  text-align: center;
                  margin-top: auto;
                  margin-bottom: auto;
                  line-height: 22px;
                #NEWSFEED_QRCODE.vertical {
                  height: 100px;
                  width: 100px;
                  min-width: 100px;
                  min-height: 100px;
                  /* display: inline-block; */
                  margin-right: 0px;
                  margin-top: 3px;
                  margin-left: 0px;
                #NEWSFEED_CONTENER_TITLE {
                  display: flex;
                #NEWSFEED_DESCRIPTION.vertical {
                  line-height: 20px;
                  margin-top: 5px;
                  -webkit-line-clamp: 10;
                #NEWSFEED_TIME.vertical {
                  font-size: 60%;
                  margin-top: 0px;
                A S 2 Replies Last reply Reply Quote 0
                  Anthony Project Sponsor @Egnos
                  @Egnos Why don’t you try different modules?
                  • E Offline
                    Egnos @Anthony
                    @Anthony said in MMM-NewsFeed multiple instances:
                    Hi @Anthony, I have not found any RSS Feed modules that show the image of the article.
                    Do you have something to advise me?
                    Thanks.
                    A 1 Reply Last reply Reply Quote 0
                      sdetweil @Egnos
                      @Egnos getStyles is in the MMM-Newfeed2.js
                        @Egnos I didn’t know you want a picture too. Although this, this and this seem to have a picture of the article but better is to check them yourself to see if they fit your needs.
