    Independent display controller based on PIR sensor.
    14 Posts 4 Posters 12.4k Views 6 Watching
      bibi
      @beh hi! i was wondering if there was an easy way to add a fading effect when the mirror goes to sleep and wake up? would be interesting in this as well? thx
      BehB 1 Reply Last reply Reply Quote 0
      • BehB Offline
        Beh @bibi
        Hi @bibi, I hope, I understand that right.
        I don’t think that this is very easy. Because the script just turns the HDMI port of the RaspberryPi to on and off. So a fading effect wouldn’t be quite easy I think
          bibi @Beh
          @Beh i understand this. No problem and thx for reply! :)
            shashank @bibi
            @bibi hi can anyone help me with screenshots the file path where to enter the below commands to start it at boot time
            cp ./pir_sensor.service /lib/systemd/system
            systemctl daemon-reload
            systemctl start pir_sensor.service
              bibi @shashank
              @shashank hi! unfortunately you will not find the cmd line in the github to enable the service at boot time. As far as i have checked, the systemd should already run at boot but for strange reasons it was not the case for me. Therefore, i had to issue the command : sudo systemctl enable pir_sensor.service
              good luck!
              • BehB Offline
                Beh
                Ok, maybe I forgot that in the readme file, or it worked straghtaway on my Pi.
                I’m going to add sudo systemctl enable pir_sensor.service to the readme file!
                thanks for the hint :)
                  McSorley
                  Sounds more effective than mine. I set an infinite loop to check for motion every second and if no motion is detected for 600 seconds the display goes to sleep.
                  • 2 / 2
