    MMM-Globe
    119 Posts 39 Posters 175.2k Views 40 Watching
    • schlachtkreuzer6S Offline
      schlachtkreuzer6 @binderth
      @binderth niiiice! :)
        @binderth the globe is cut at south pole area, i think the white slice down there is the background color
        so i think the module cut a circle out of the webpage and down there is some part of the earth missing, or out of view. Also i got another issue: If I´m using the random Photo Module as background, i see a small black border around the full globe. So to fix that, there must be an adjustment for the size of the cutting circle. But anyway the main problem with that white slice is, the image source.
        SvenSommerS 1 Reply Last reply Reply Quote 0
          shgmongohh @binderth
          @binderth
          If I have a bit more time, I’d like to add the standard ones and make a pull request to choose from. There’s a list of (near) real-time images from EUMETSAT: http://oiswww.eumetsat.org/IPPS/html/latestImages.html
          Very nice work!
          It would be awesome, if you could add the real time images!
          Sebastian
          schlachtkreuzer6S 1 Reply Last reply Reply Quote -1
            schlachtkreuzer6 @shgmongohh
            @shgmongohh that would be awesome! thank you in advance :)
            • SvenSommerS Offline
              SvenSommer @schlachtkreuzer6
              @schlachtkreuzer6
              Hey guys,
              I was able to cut the white bar by cutting the last pixels (depending on the image size) from this image with adding the following to MMM-Globe.js
              getDom: function () {
                  var wrapper = document.createElement("div");
                  if (this.config.style == "europeDiscNat") {
              	wrapper.style.height = 0.98 * this.config.imageSize - 1 + "px";
              	wrapper.style.overflow = "hidden";
                  var image = document.createElement("img");
              Looking for some building inspiration?
              Check out my large, thin and metal framed mirror on robstechlog.com.
              Modules released:
              MMM-GoogleAnalytics
              MMM-GrafanaChart
              MMM-GrafanaGauges
              schlachtkreuzer6S 1 Reply Last reply Reply Quote 1
                schlachtkreuzer6 @SvenSommer
                @SvenSommer Nice work! Thanks. Post it on github as well :)
                  @schlachtkreuzer6
                  done, I also included the sources from binderth and made a pull request.
                  Modules released:
                  MMM-GoogleAnalytics
                  MMM-GrafanaChart
                  MMM-GrafanaGauges
                  LukeCodewalkerL lolobyteL 2 Replies Last reply Reply Quote 1
                  • LukeCodewalkerL Offline
                    LukeCodewalker Module Developer @SvenSommer
                    @SvenSommer
                    could you please adjust the README.md that it contains your additional image-styles? then i will merge your pull request =)
                    thanks for your help improving the module
                    • lolobyteL Offline
                      lolobyte @SvenSommer
                      @SvenSommer
                      Wrong, the picture source information was from me.
                      You can read my first entry above the post from @binderth !
                        SvenSommer
                        @lolobyte
                        Sorry. So, thank you for this excellente source!
                        @LukeCodewalker
                        readme is adjusted.
                        Modules released:
                        MMM-GoogleAnalytics
                        MMM-GrafanaChart
                        MMM-GrafanaGauges
                        LukeCodewalkerL 1 Reply Last reply Reply Quote 0
                        • 11
                        • 12
                        • 3 / 12
