    Bugsounet and MMM-Pir
    Scheduled Pinned Locked Moved General Discussion
    68 Posts 10 Posters 9.5k Views 11 Watching
      rkorell @sdetweil
      @sdetweil said in Bugsounet and MMM-Pir:
      hard to examine code
      Yes, I guess this was bugsounet’s intention - irritating beginners :-)
      The code has 247 lines so you avoid 247 CR’s - not THAT much more efficient, I think - but on 100eds of 1000nds of files - may be …
      Ralf
        sdetweil @rkorell
        @rkorell he did not do it for performance
        R 1 Reply Last reply Reply Quote 1
          rkorell @sdetweil
          @sdetweil I agree :-)
            rkorell @rkorell
            @rkorell said in Bugsounet and MMM-Pir:
            in the src folder of the repository
            @lif , @coernel :
            there are several files missing in coernels upload.
            I’ve just checked source code in MMM-Pir.js …
                  "/modules/MMM-Pir/components/screenDisplayer.js",
                  "/modules/MMM-Pir/components/screenTouch.js",
                  "/modules/MMM-Pir/node_modules/long-press-event/dist/long-press-event.min.js",
                  "/modules/MMM-Pir/node_modules/progressbar.js/dist/progressbar.min.js",
                  "/modules/MMM-Pir/components/motion.js",
                  "/modules/MMM-Pir/components/motionLib.js"
            The complete folder MMM-Pir/node_modules is missing.
            The folder MMM-Pir/components/ contains only the python script for PIR communication, none of the above *.js files.
            At least the /components/*.js files are present in the components folder of MMM-Pir/src …
            But this seems to be a frickling job to get this done.
            I guess a complete upload of an original MMM-Pir installation would be the better way.
            What do you think?
            Regards,
            Ralf
              sdetweil @rkorell
              @rkorell because they are in node_modules they were dependencies , not part of the actual module…
              R 1 Reply Last reply Reply Quote 0
                rkorell @sdetweil
                As far as I understood @coernel tried to re-upload bugsounet’s MMM-Pir.
                And this modules uses all of these dependencies.
                And the original MMM-Pir.js from bugsounet is missing as well in coernel’s re-upload, so it will never work - which is, what @lif has experienced …
                So my above suggestion was - if it is intended to have a working copy of bugsounet’s module - to re-investigate the re-uploaded version because there is missing a lot - as mentioned even the core *.js file in the root of the module…
                If useful for anybody I’ve created a complete copy of my own working module-directory and uploaded it here for your attention/action.
                Please ignore some additional files which I have kept as copies of the original files I had modified.
                Hope this is clearer now :-)
                Regards,
                Ralf
                  sdetweil @rkorell
                  @rkorell yes, i posted a warning early after he left to save what you could, without knowing the details of such work effort
                    rkorell @sdetweil
                    @sdetweil Yes, indeed - we had a chat at these time as you might remember.
                    And here seems to be an opportunity to do “something” against this "bug"sounet thingi …
                    As @coernel suggested a re-upload could help (a little bit), so I considered this as a really good and nice idea.
                    But it went wrong - for unknown reasons the given copy is incomplete.
                    So my suggestion to complete this ta - at least - have a working copy of an elder status …
                    Ralf
                      sdetweil @rkorell
                      @rkorell yeh, or forget it and move to a current module.
                      very troubling
                      L R 2 Replies Last reply Reply Quote 0
                      • L Offline
                        lif @sdetweil
                        Thank you everyone, I’m sorry for opening this can of worms.
                        I’ve now got a Python script that runs at boot and does the job after destroying my MM installation trying to apply upgrades.
                        • 6
                        • 7
                        • 4 / 7
