    [ERROR] _ is not defined
    36 Posts 3 Posters 1.8k Views 3 Watching
      nowayto
      I have an issue, appeared after MMM-SolarPicture installation but I don’t think it’s related to it. Maybe an error on my configuration.
      pm2 logs is this one below
      0|mm | [2025-05-08 21:00:29.772] [ERROR] _ is not defined
      0|mm | [2025-05-08 21:00:29.826] [ERROR] _ is not defined
      0|mm | [2025-05-08 21:01:53.233] [ERROR] _ is not defined
      0|mm | [2025-05-08 21:01:53.327] [ERROR] _ is not defined
      0|mm | [2025-05-08 21:03:16.264] [ERROR] _ is not defined
      0|mm | [2025-05-08 21:03:16.440] [ERROR] _ is not defined
      0|mm | [2025-05-08 21:04:39.584] [ERROR] _ is not defined
      0|mm | [2025-05-08 21:04:39.676] [ERROR] _ is not defined
      0|mm | sh: 1: ./node_modules/.bin/electron: not found
      0|mm | sh: 1: sh: 1: ./node_modules/.bin/electron: not found
      0|mm | ./node_modules/.bin/electron: not found
      0|mm | > [email protected] start
      0|mm | > npm run start:x11
      0|mm | > [email protected] start:x11
      0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      PM2 | App [mm:0] exited with code [0] via signal [SIGINT]
      PM2 | App [mm:0] starting in -fork mode-
      PM2 | App [mm:0] online
      npm run config:check gave me that result:
      [email protected] config:check
      node js/check_config.js
      node:internal/modules/cjs/loader:1228
      throw err;
      Error: Cannot find module ‘eslint’
      Require stack:
      • /home/MYMIRRORNAME/MagicMirror/js/check_config.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
        at Module._load (node:internal/modules/cjs/loader:1051:27)
        at Module.require (node:internal/modules/cjs/loader:1311:19)
        at require (node:internal/modules/helpers:179:18)
        at Object. (/home/MYMIRRNAME/MagicMirror/js/check_config.js:6:20)
        at Module._compile (node:internal/modules/cjs/loader:1469:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1548:10)
        at Module.load (node:internal/modules/cjs/loader:1288:32)
        at Module._load (node:internal/modules/cjs/loader:1104:12)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:173:12) {
        code: ‘MODULE_NOT_FOUND’,
        requireStack: [ ‘/home/MYMIRRORNAME/MagicMirror/js/check_config.js’ ]
      Node.js v20.18.1
      thank you for your help
        nowayto @sdetweil
        Sam… I don’t know how to saying it.
        I figure out the issue.
        After your last message I tried what you suggest.
        With the default cfg I had no errors, with mine I had errors.
        So I checked again and again the config…
        and I find an underscore _ right at the start of the config
        npm config:check told me “no syntax errors” and that confusing me.
        When I edit it I use nano editor
        I do “sudo nano config.js” and I press CTRL + _ to jump at the 250 line.
        Might be one of the latest time I opened it and press _ a bit faster than CTRL and I add it for error.
        In addition I notice that when I open config.js with nano editor the green cursor is, clearly, at the start of the first line… EXACTLY on the undescore _ and it hides it.
        I’m really sorry for bothering you with that.
        How can I buy you a coffee ?
          sdetweil @nowayto
          @nowayto >Node.js v20.18.1
          2.31.0 requires node 22.14 or above
          how did you get here?
          also you are on 2.31.0-develop
          so you had a temp fix
          and didn’t read the post i put out
          https://forum.magicmirror.builders/topic/19561/version-2.31.0-april-1-2025-upgrade-reminder
          N 2 Replies Last reply Reply Quote 0
            nowayto @sdetweil
            @sdetweil I didn’t update MM since I’ve installed it months ago, so I suppose it wasn’t that. Might be it updated automatically?
            I remember you told me to use a “temp fix” to solve a problem.
            Now I’ll follow your guide in the post to update it.
              nowayto @sdetweil
              @sdetweil Do you suggest to update manually or auto? Thanks
                sdetweil @nowayto
                @nowayto i never suggest update automatically.
                use my script
                N 1 Reply Last reply Reply Quote 0
                  nowayto @sdetweil
                  @sdetweil I’m sorry for the question: that script?
                  bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                    sdetweil @nowayto
                    @nowayto yes, but its two steps
                    one time without any parameters (test mode)
                    and one time with apply
                    all you have to do is click/copy the first time and run it
                    then do the same on the second if the first ends successfully
                      nowayto @sdetweil
                      @sdetweil MM doesn’t work.
                      I tried a config check but I have this error now.
                      I tried to “npm install eslint -g” but the error persist
                      node:internal/modules/cjs/loader:1404
                      throw err;
                      Require stack:
                      • /home/MYMIRR/MagicMirror/js/check_config.js
                        at Module._resolveFilename (node:internal/modules/cjs/loader:1401:15)
                        at defaultResolveImpl (node:internal/modules/cjs/loader:1057:19)
                        at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1062:22)
                        at Module._load (node:internal/modules/cjs/loader:1211:37)
                        at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                        at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
                        at Module.require (node:internal/modules/cjs/loader:1487:12)
                        at require (node:internal/modules/helpers:135:16)
                        at Object. (/home/MYMIRR/MagicMirror/js/check_config.js:6:20)
                        at Module._compile (node:internal/modules/cjs/loader:1730:14) {
                        requireStack: [ ‘/home/MYMIRR/MagicMirror/js/check_config.js’ ]
                      Node.js v22.15.0
                        sdetweil @nowayto
                        @nowayto show me the ~/MagicMirror/installers/upgrade.log
                        note: I had a typo in log filename
                        and then do
                        cd ~/MagicMirror
                        npm install
                          nowayto @sdetweil
                          Upgrade started - Sat May 10 00:06:51 CEST 2025
                          system is Linux magicmirror2 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                          doing test run = true, NO updates will be applied!
                          the os is PRETTY_NAME=“Raspbian GNU/Linux 11 (bullseye)” NAME=“Raspbian GNU/Linux” VERSION_ID=“11” VERSION=“11 (bullseye)” VERSION_CODENAME=bullseye ID=raspbian ID_LIK>
                          architecture from dpkg is armhf
                          ^[[96mCheck current Node installation …^[[0m
                          ^[[0mNode currently installed. Checking version number.
                          ^[[0mMinimum Node version: ^[[1mv22.14.0^[[0m
                          ^[[0mInstalled Node version: ^[[1mv22.15.0^[[0m
                          ^[[92mNo Node.js upgrade necessary.^[[0m
                          ^[[96mCheck current NPM installation …^[[0m
                          ^[[0mNPM currently installed. Checking version number.
                          ^[[0mMinimum npm version: ^[[1mV10.9.2^[[0m
                          ^[[0mInstalled npm version: ^[[1mV11.3.0^[[0m
                          ^[[92mNo npm upgrade necessary.^[[0m
                          saving custom.css
                          remote name = origin
                          upgrading from version 2.31.0 to 2.31.0
                          fetching latest revisions
                          git fetch rc=0
                          current branch = master
                          On branch master
                          Your branch is up to date with ‘origin/master’.
                          Untracked files:
                          (use “git add …” to include in what will be committed)
                          core
                          errorcal.txt
                          errorcal2.txt
                          errorcal3.txt
                          errorcal4.txt
                          errorcal5.txt
                          nohup.out
                          run-start.sh
                          splashscreen/
                          nothing added to commit but untracked files present (use “git add” to track)
                          no files different from github version
                          • 1 / 4
