[ERROR] _ is not defined
@sdetweil Thank you a lot Sam.
I did everything but
I have an [ERROR] _ is not defined[email protected] start:x11
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js[2025-05-11 15:39:26.429] [LOG] Starting MagicMirror: v2.31.0
[2025-05-11 15:39:26.527] [LOG] Loading config …
[2025-05-11 15:39:26.537] [LOG] config template file not exists, no envsubst
[2025-05-11 15:39:28.154] [INFO] Checking config file /home/MYMIRR/MagicM irror/config/config.js …
[2025-05-11 15:39:28.478] [INFO] Your configuration file doesn’t contain syntax errors :)
[2025-05-11 15:39:28.482] [INFO] Checking modules structure configuration …
[2025-05-11 15:39:28.793] [ERROR] _ is not defined -
@nowayto so that sounds like the npm install failed again
do it again and show the output
installer didn’t failed, but this is the result now
npm install
[email protected] postinstall
npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
"[email protected] install-vendor
echo "Installing vendor files …
" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifierInstalling vendor files …
up to date in 7s
[email protected] install-fonts
echo "Installing fonts …
" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifierInstalling fonts …
up to date in 3s
MagicMirror² installation finished successfully![email protected] prepare
[ -f node_modules/.bin/husky ] && husky || echo no husky installed.up to date in 45s
285 packages are looking for funding
runnpm fund
for details -
@nowayto weird, and npm start fails again _ not defined?
i installed solarpicture without problems
I’m sure.I don’t think SolarPicture could be the problem.Yes, the error keep showing
@nowayto wild, lets do this… intall MM again, but save the current…
#backup MM config and modules list bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" #rename the MagicMirror folder out of the way cd ~ mv MagicMirror MagicMirror.save #and install MM again bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)" #restore the MM config and modules bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_restore.sh)"
then
cd ~/MagicMirror npm start
Before writing here I made backups, locally and on github, like you taught me in the past :)Now I’ll try
That’s incredible… I did it, everything goes good… no issues but when I start it
npm start
npm run start:x11[email protected] start:x11
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js[2025-05-11 22:44:21.593] [LOG] Starting MagicMirror: v2.31.0
[2025-05-11 22:44:21.682] [LOG] Loading config …
[2025-05-11 22:44:21.687] [LOG] config template file not exists, no envsubst
[2025-05-11 22:44:23.250] [INFO] Checking config file /home/MYMIRR/MagicMirror/config/config.js …
[2025-05-11 22:44:23.532] [INFO] Your configuration file doesn’t contain syntax errors :)
[2025-05-11 22:44:23.535] [INFO] Checking modules structure configuration …
[2025-05-11 22:44:23.824] [ERROR] _ is not definedAgain this _ is not defined
@nowayto wow!!! NOW i am really confused.
have you rebooted?
if you try the sample config.js
cd ~/MagicMirror/config mv config.js config.js.save cp config.js.sample config.js
and then
npm startdoes it run or fail
Sam… I don’t know how to saying it.
I figure out the issue.After your last message I tried what you suggest.
With the default cfg I had no errors, with mine I had errors.So I checked again and again the config…
and I find an underscore _ right at the start of the confignpm config:check told me “no syntax errors” and that confusing me.
When I edit it I use nano editor
I do “sudo nano config.js” and I press CTRL + _ to jump at the 250 line.
Might be one of the latest time I opened it and press _ a bit faster than CTRL and I add it for error.In addition I notice that when I open config.js with nano editor the green cursor is, clearly, at the start of the first line… EXACTLY on the undescore _ and it hides it.
I’m really sorry for bothering you with that.
How can I buy you a coffee ?
