White screen after MMM-Remote-Control update
I have run the update on the MMM-Remote-Control module, and now get a white screen when starting MagicMirror.
If I // the lines on the MMM-Remote-Control module in the config.js the Mirror shows up normally. I have deleted and reinstalled the MMM-Remote-Control module but the problem remains.Any advice? I do like the functionality of the Remote Control module.
Is missing body-parser lib required by MMM-Remote-Control
Go the module directory and run npm install
cd /home/pi/MagicMirror/modules/MMM-Remote-Control/ npm install
@Hein-Jan any errors in the logs that you can provide?
Having the same problem… Any suggestions?
pi@raspberrypi:~/MagicMirror $ node serveronly
Starting MagicMirror: v2.1.0
Loading config …
Loading module helpers …
No helper found for module: alert.
Initializing new module helper …
No helper found for module: clock.
No helper found for module: compliments.
No helper found for module: currentweather.
No helper found for module: weatherforecast.
No helper found for module: calendar_monthly.
WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘body-parser’
Whoops! There was an uncaught exception…
{ Error: Cannot find module ‘body-parser’
at Function.Module._resolveFilename (module.js:469:15)
at Function.Module._load (module.js:417:25)
at Module.require (module.js:497:17)
at require (internal/module.js:20:19)
at Object. (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:15:20)
at Module._compile (module.js:570:32)
at Object.Module._extensions…js (module.js:579:10)
at Module.load (module.js:487:32)
at tryModuleLoad (module.js:446:12)
at Function.Module._load (module.js:438:3) code: ‘MODULE_NOT_FOUND’ }
MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
pi@raspberrypi:~/MagicMirror $ git pull -
@roramirez Experience the same issue and was fixed by following your instructions! Thanks a bunch!
Thanks, all good now
@roramirez.
Thanks, you have hit the nail on the head. I did run the git pull command, I have run the reinstall (the script did not work so I ran the manual method, but I did not run the npm install.
Sorry, I am new at this.
I did search the forum but could not find a solution.So, thank for pointing out my mistake and helping me rectify it.
@ others: thanks for sharing your problems and logs so the problem could be solved.
Case closed from my perspective.
@Hein-Jan Sorry about this, forgot to mention, that the new version introduces dependencies which must be installed.
@roramirez answer should work for anyone having the same problem (thanks!).
