    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    Scheduled Pinned Locked Moved System
    274 Posts 78 Posters 743.6k Views 77 Watching
    • foxF Offline
      fox
      @Jopyth have you changed something on the screen?
      Now on the devices the page losts the icons and back buttons etc.
      Tested on iOS, linux, laptop, handy, tablet. Everywhere the same effect:
      alt text
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
      strawberry 3.141S 1 Reply Last reply Reply Quote 0
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @fox
        @fox the module didn’t update the path to the icons that has changed in v2.1.1 yet.
        Please create a github issue if you need help, so I can keep track
        K foxF 2 Replies Last reply Reply Quote 0
        • K Offline
          kurt @strawberry 3.141
          @strawberry-3.141
          how can we update the path?
          cause I’ve got the same effect with lost icons, even after a git pull and npm install in the MMM-Remote-Control modul.
          Thanke you
            strawberry 3.141 Project Sponsor Module Developer @kurt
            @kurt as far as i can see it is merged into the dev branch
            to change to dev branch do the following
            cd ~/MagicMirror/modules/MMM-Remote-Control
            git fetch
            git checkout develop
            K 1 Reply Last reply Reply Quote 0
            • foxF Offline
              fox @strawberry 3.141
              @strawberry-3.141
              What do you mean? That I can fix it with an update ?
              • ? Offline
                A Former User
                Can anyone post a example of his config, so I can see what to do to switch on/off the single modules? I only do have the default values there, shutdown etc…
                Appreciate your help, thx
                foxF 1 Reply Last reply Reply Quote 0
                • foxF Offline
                  fox @Guest
                  @PatrickGlatz
                  You should oopen it on a device: :8080/remote.html and after you changed sth you will see, that your config has been greatly rewritten! :-)
                  So no need to change other modules configs
                  • K Offline
                    @strawberry-3.141
                    thank you, the icons are here again :slight_smile:
                    I’ll try to install pm2 so I can use the New start and Switch off feature.
                    • P Offline
                      pepemujica
                      Hi @Jopyth !
                      I’m trying to acces from my smartphone, but I have no answer.
                      From the browser were is runnig the MM I am able to run the contrl, but not from other device. Any idea why?
                      Kind regards
                        strawberry 3.141 Project Sponsor Module Developer @pepemujica
                        @pepemujica check your whitelist settings
                        P 1 Reply Last reply Reply Quote 0
                        • 17
                        • 18
                        • 19
                        • 20
                        • 21
                        • 27
                        • 28
                        • 19 / 28
