    Change Modules name
    Scheduled Pinned Locked Moved Forum
    7 Posts 5 Posters 4.1k Views 6 Watching
    • yawnsY Offline
      yawns Moderator @pepemujica
      @pepemujica
      Sure. Change the name of the folder, the name of the module.js and the module name inside the module.js file
      P 1 Reply Last reply Reply Quote 0
      • P Offline
        pepemujica @yawns
        @yawns great, and can I copy the folder, so I have the original module with it’s original name, and the copy with the custom name?
        Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
        • Mykle1M Offline
          Mykle1 Project Sponsor Module Developer @pepemujica
          @pepemujica
          Yes, just make the changes that @yawns stated above
          Create a working config
          • cowboysdudeC Offline
            cowboysdude Module Developer @pepemujica
            @pepemujica No.
            If you have [for example] MMM-This and you want MMM-That you have to change the folder name first to MMM-That…
            Now…inside that folder change MMM-This.js to MMM-That.js
            THEN open MMM-That.js and at the top it will have this line ---->
            Module.register(“MMM-This”, {
            That has to be changed to:
            Module.register(“MMM-That”, {
            Save the file…
            NOW some issues you may encounter… IF in MMM-That there is a line like this —>
            getStyles: function() {
            return [“MMM-This.css”];
            That could potentially also need to be changed… IF you change it there you must go into the directory and rename MMM-This.css to MMM-That.css
            IF you do that then you need to open MMM-That.css and inside there will be this ->>>
            .MMM-This .photo {
            width:125px;
            height:125px;
            They ALL have to be changed to MMM-That as well.
            Then you have renamed it …
              shbatm Module Developer
              On the Raspberry Pi, a shortcut to renaming all of the instances of ‘MMM-This’ inside the files is to use the following​ command. Don’t forget to navigate to the new module’s directory!
              find . -type f | xargs sed -i 's/MMM-This/MMM-That/g'
              You still need to rename the actual files.
              • Mykle1M Offline
                Or, for those not comfortable (yet) with the terminal, just about any text editor (including the Pi’s) can do a “Find and Replace”.
