    Todoist accesstoken
    Scheduled Pinned Locked Moved Troubleshooting
    9 Posts 5 Posters 4.8k Views 5 Watching
      sizer
      Did you figure it out??
      N 1 Reply Last reply Reply Quote 0
        ninjabreadman @sizer
        @sizer Go here:
        1. Create an app (e.g. “My Private MagicMirror”) in the developer’s console. If you don’t have a website, use example.com.
        2. Then with your client ID and secret, construct an OAuth query (with whatever scope your app will need) and visit in a browser.
        3. It will then redirect you to your app’s website with a code parameter. (If using example.com, it will fail to reach the site; just look at the address bar and find the code parameter.)
        4. Use thecode parameter to exchange for an access token (e.g. using curl):
        $ curl "https://todoist.com/oauth/access_token" \
            -d "client_id=0123456789abcdef" \
            -d "client_secret=secret" \
            -d "code=abcdef" \
            -d "redirect_uri=https://example.com"
        Problem with config or JavaScript? Copy/paste it into JSHint.
        Check out the detailed walkthroughs on install, config, modules, etc.
        zdenekZ 1 Reply Last reply Reply Quote 1
        • zdenekZ Offline
          zdenek @ninjabreadman
          @ninjabreadman great, but I’m lost. 1. is clear, but what to do now, where to construct OAuth (whetever is it)…?..
          thanks, Zdeněk
            ninjabreadman @zdenek
            @zdenek Go here. Follow the instructions to create an OAuth string, that will look something like this:
            https://todoist.com/oauth/authorize?client_id=0123456789abcdef&scope=data:read,data:delete&state=secretstring
            zdenekZ 1 Reply Last reply Reply Quote 0
            • zdenekZ Offline
              @ninjabreadman thx. My steps:
              1. went to https://todoist.com/oauth/authorize?client_id=0123456789abcdef&scope=data:read,data:delete&state=secretstring
                where I used my client_id and a “state” used "client_secret
              2. got
                https://example.com/?state=client_secert&code=string_of_characters
              3. on MM from commandlind I run
                  -d "client_id=my_client_id" \
                  -d "client_secret=my_client_secret" \
                  -d "code=string_from_previous_step" \
              1. got answer
                “access_token”:“another_string”,“token_type”:“Bearer”
              so, I guess, that “another_string” is the right think for the module = access_token, right?
              			module: 'MMM-Todoist',
              			position: 'top_center',	// This can be any of the regions. Best results in left or right regions.
              			//header: 'Todoist', // This is optional
              			config: { // See 'Configuration options' for more information.
               		         	accessToken: 'axxxxxxxxxxb',
              				maximumEntries: 60,
              				updateInterval: 10*60*1000, // Update every 10 minutes
              				//projects: [ 166564794 ],
              				fade: false
              should be OK, but nothing :-(. Checked in browser:
              div id="module_10_MMM-Todoist" class="module MMM-Todoist MMM-Todoist">div class="module-content">table class="normal small light">/table>/div>/div>
              (removed < signs)
              in Console no Warnings, no Erros…
              any idea?
              • zdenekZ Offline
                zdenek
                i’m soooooooooo stupid sorry. I thougt, without define any ProjectID I’ll get ToDo of all Projects in my account. Nope. After add of at least one ID, it works…
                sorry for annoying …
                Zdeněk
                  @zdenek No problem, it happens to all of us. Glad to hear it’s working!
                    AgP42 Project Sponsor Module Developer
                    Hello all,
                    I also get so many trouble to make it work, but thanks to your help it is now ok ! :grinning_face:
                    So no need to create that incredibly complicated “OAuth string”, the use of the “Test token” works perfectly fine :
                    But… It is mandatory to define “projects” value in the config.js file.
                    As the default value is [] I also consider it as optional…:flushed_face:
                    With this value defined, everything is OK !
