    MMM-NOAA - Another Weather Module
    Scheduled Pinned Locked Moved System
    690 Posts 77 Posters 2.5m Views 70 Watching
      costascontis
      openweather is your problems ,ditch that api and create a free new one at darksky provider.Dont forget to Put your Lat and Long at config.
        Anthony Project Sponsor @Mykle1
        @mykle1 If I do the same for Greek translation will someone fix it for the module?
        • cowboysdudeC Offline
          cowboysdude Module Developer
          Yeah I’m sure ‘someone’ will fix it LOL
          IF this is correct:
          “Rise”:“Восход”,
          “Set”:“Закат”,
          “4 Day Forecast”:“Прогноз на 4 дня”,
          “Monday”: “Понедельник”,
          “Tuesday”: “Вторник”,
          “Wednesday”: “Среда”,
          “Thursday”: “Четверг”,
          “Friday”: “Пятница”,
          “Saturday”: “Суббота”,
          “Sunday”: “Воскресенье”,
          “Hours of Light”:“Длительность дня”,
          “Last Updated”: “Последнее обновление”,
          “Today”:“Сегодня”,
          “Night”:“Ночь”,
          “Mon”:“Пн”,
          “Tue”:“Вт”,
          “Wed”:“Ср”,
          “Thu”:“Чт”,
          “Fri”:“Пт”,
          “Sat”:“Сб”,
          “Sun”:“Вс”,
          “No Wind”: “Штиль”,
          “Humidity”: “Влажность”,
          “Visibility”:“Видимость”,
          “Pressure”:“Давление”,
          “Excellent”:“Отлично”,
          “Good”:“Хорошо”,
          “Lightly Polluted”:“Легкие загрязнения”,
          “Moderately Polluted”:“Умеренные загрязнения”,
          “Heavily Polluted”:“Сильные загрязнения”,
          “Forecast”:“Прогноз”
          I just added it to NOAA3… let me know if anything is wrong.
          A 1 Reply Last reply Reply Quote 1
            Here is the Greek translation. I also tried to make a pull request on github but I am not sure If I did it right since this is my first pull request. I hope someone will fix it :winking_face: :winking_face: :winking_face:
            Thank you very much.
            “Rise”:"Ανατολή",
            “Set”:"Δύση",
            “4 Day Forecast”:"Πρόβλεψη 4 Ημερών",
            “Monday”:"Δευτέρα"
            “Tuesday”:"Τρίτη",
            “Wednesday”:"Τετάρτη",
            “Thursday”:"Πέμπτη",
            “Friday”:"Παρασκευή",
            “Saturday”:"Σάββατο",
            “Sunday”:"Κυριακή",
            “Hours of Light”:"Διάρκεια Ημέρας",
            “Last Updated”:"Τελευταία Ενημέρωση",
            “Today”:"Σήμερα"
            “Night”:"Νύχτα",
            “Mon":"Δευ",
            “Tue”:"Τρι"
            “Wed”:"Τετ",
            “Thu”:"Πεμ",
            “Fri”:"Παρ",
            “Sat”:"Σαβ",
            “Sun”:"Κυρ",
            “No Wind”:"'Οχι Άνεμος",
            “Humidity”:"Υγρασία",
            “Visibility”:"Ορατότητα",
            “Pressure”:"Πίεση"
            “Excellent”:"Έξοχος",
            “Good”:"Καλός",
            “Lightly Polluted”:"Ελαφριά Ρύπανση",
            “Moderately Polluted”:"Μέτρια Ρύπανση",
            “Heavily Polluted":"Βαριά Ρύπανση",
            “Forecast”:"Πρόβλεψη"
              Anthony Project Sponsor @cowboysdude
              @cowboysdude I just noticed that you have made a small mistake in NOAA’s translations folder in github. You have named the Russian translation as Greek. Check it out when you have the time.
              cowboysdudeC 1 Reply Last reply Reply Quote 1
                cowboysdude Module Developer @Anthony
                @anthony I added a gr.json file which should be the greek one :) Not sure how I could mix them up there is no ru.json so not sure how they got mixed up LOL
                A 2 Replies Last reply Reply Quote 0
                  @cowboysdude I saw that you replaced the content of gr.json. So now you have to make a ru.json for the russian translation since you have it already. Thank you for merging the translation. Can’t wait to go home to test how it looks. Although the last 4 days the 4 day forecast is not showing any pictures. Do you have any idea what might be the problem? I have uninstall/reinstall the module, restart the MM and the pi several times but nothing.
                  cowboysdudeC 1 Reply Last reply Reply Quote 0
                    @cowboysdude I made the update and nothing changed in the module’s language. Still in English. I changed the language in my config.js from “en” to “gr” but then only black screen when I restart MM. Am I doing something wrong or something in the translation is wrong?
                      @anthony run your mirror in dev mode - npm start dev and if there’s an error you’ll see it and it’ll name the module. Let me know what it says :) We’ll get it working!
                        @cowboysdude
                        Are these logs suspicious?:
                        MMM-Remote-Control received a module notification: WEATHER from sender: MMM-NOAA3
                        module.js:154 clock received a module notification: WEATHER from sender: MMM-NOAA3
                        module.js:154 calendar received a module notification: WEATHER from sender: MMM-NOAA3
                        module.js:154 MMM-Cursor received a module notification: WEATHER from sender: MMM-NOAA3
                        module.js:154 MMM-SystemStats received a module notification: WEATHER from sender: MMM-NOAA3
                        module.js:154 MMM-horoscope received a module notification: WEATHER from sender: MMM-NOAA3
                        module.js:154 mmm-food2fork-recipes received a module notification: WEATHER from sender: MMM-NOAA3
                        module.js:154 MMM-MovieInfo received a module notification: WEATHER from sender: MMM-NOAA3
                        module.js:154 MMM-History received a module notification: WEATHER from sender: MMM-NOAA3
                        module.js:154 MMM-RadioDe received a module notification: WEATHER from sender: MMM-NOAA3
                        I can’t see any errors except some electron warnings.
                        Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
                            protocols.This exposes users of this app to unnecessary security risks.
                            Consider loading the following resources over HTTPS or FTPS.
                         - http://0.0.0.0:8080/css/main.css
                        - http://0.0.0.0:8080/fonts/roboto.css
                        - http://0.0.0.0:8080/socket.io/socket.io.js
                        - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
                        - http://0.0.0.0:8080/js/defaults.js
                        - http://0.0.0.0:8080/config/config.js
                        - http://0.0.0.0:8080/vendor/vendor.js
                        - http://0.0.0.0:8080/modules/default/defaultmodules.js
                        - http://0.0.0.0:8080/js/logger.js
                        - http://0.0.0.0:8080/translations/translations.js
                        - http://0.0.0.0:8080/js/translator.js
                        - http://0.0.0.0:8080/js/class.js
                        - http://0.0.0.0:8080/js/module.js
                        - http://0.0.0.0:8080/js/loader.js
                        - http://0.0.0.0:8080/js/socketclient.js
                        - http://0.0.0.0:8080/js/main.js
                        - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
                        - http://0.0.0.0:8080/translations/en.json
                        - http://0.0.0.0:8080/modules/MMM-pages//MMM-pages.js
                        - http://0.0.0.0:8080/modules/MMM-pages/pages.css
                        - http://0.0.0.0:8080/modules/MMM-Remote-Control//MMM-Remote-Control.js
                        - http://0.0.0.0:8080/modules/MMM-Remote-Control/remote-control.css
                        - http://0.0.0.0:8080/modules/MMM-page-indicator//MMM-page-indicator.js
                        - http://0.0.0.0:8080/vendor/node_modules/font-awesome/css/font-awesome.min.css
                        - http://0.0.0.0:8080/modules/MMM-page-indicator/page-indicators.css
                        - http://0.0.0.0:8080/modules/default/alert//alert.js
                        - http://0.0.0.0:8080/modules/default/alert/classie.js
                        - http://0.0.0.0:8080/modules/default/alert/modernizr.custom.js
                        - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
                        - http://0.0.0.0:8080/modules/default/alert/ns-default.css
                        For more information and help, consult
                        https://electronjs.org/docs/tutorial/security.
                         This warning will not show up
                        once the app is packaged.
                        Any help appreciated.
                        • 57
                        • 58
                        • 59
                        • 60
                        • 61
                        • 68
                        • 69
                        • 59 / 69
