    MM2 my first try
    21 Posts 8 Posters 7.0k Views 7 Watching
      seramik
      hi guys
      i just bought my rpi 3B+
      it seems ok for me with raspbian, it worked
      so i launch the automatic install
      then :
      installing dependencies…
      bash: ligne112: npm: commande introuvable
      unable to install dependencies!
      so any advices ? what i’ve done wrong ?
      G 1 Reply Last reply Reply Quote 0
      • G Offline
        ganget @seramik
        @seramik a good question with way too less info to give a good answer. maybe this install guide can help you further!
          seramik
          @ganget said in MM2 my first try:
          thanks for the tutorial
          actually, my problem is on the magicmirror² installation, the step 1 dont run properly
          but i will try again from the start
          Mykle1M 1 Reply Last reply Reply Quote 0
          • Mykle1M Offline
            Mykle1 Project Sponsor Module Developer @seramik
            @seramik
            This is just a shot in the dark but are node and npm up to date? Older versions of node and npm often cause this.
            Create a working config
              seramik
              for the tutorial, it is an very old version, now the first setup is quicker and the ver of MM is very old ( not even mm²)
              so dont advices those kind of thinks …
              i’ve retry for the star and it mades the same trouble
              node version is V8.11.1
              minimum ver required is V5
              i dont know for npm, how to know ?
              • Mykle1M Offline
                @seramik
                node -v
                Edit: npm -v
                  seramik
                  fine, i’ve done correct upgrade and manual install
                  mm² is running
                  i saw him then i stop it with alt key and quit option
                  i’m trying to setup the config.js file
                  and i wonder how i can restart the mm² programm again
                    seramik
                    ok i’ve found that in term , in the correct directory, i write " npm start" and it start
                    i try to understand the config file, i just copied the sample file by changing his name
                    now i will try to change the city for the weather
                      secdude
                      had the same issue with a brand spankin new installation of raspian noobs full and apt-get update/upgrade/dist-upgrade done. freshly set up. the install oneliner failed. only manual setup worked. using a rpi3. maybe there’s a broken dependency somewhere?
                        seramik
                        enought for tonight, i’ve got the weather in my town
                        not so bad for a first day and i dont speak of the weather
                        • 1 / 3
