Calendar time - capitalize first letters
Currently the calendar times are only partly capitalized, some time phrases start with lower-case letters, some don’t
(The ones pulled from the ‘translations’ folder start with upper-case letters):I have changed this behavior in my calendar.js to create a more standardized layout:
Also, I have sent a pull request to have my changes merged into the development branch,
so if you’d like to comment on this modification, feel free to do so :) -
I have found another detail that bothered me. If the calendar is set to ‘relative, 6 hours before an event occurs the calendar would start showing the time in relative terms (for example: “In 5 hours” - but then it would stay that way until it would switch to “In 4 hours” an hour later, which is pretty confusing as far as I’m concerned. If I’'m not mistaken, it stays pretty vague until 45 minutes before the event when the countdown truly starts).
I found this behavior rather counter-intuitive, as I might want to check the mirror to find out the exact time when an event starts. This is why I have introduced a tag
getRelative
, which can take any value between 0 and 48 hours. So if a user configures their calendar like this:modules: [ ... { module: 'calendar', position: 'top_left', config: { getRelative: 0.5 } } }, ...
their events start getting relative half an hour before the event (“In 30 minutes”), if they decide they don’t like relative times at all, they can set it like this:
getRelative: 0
. This way, it is easier for users to customize the calendar’s relative behavior to their needs.This is now included in my pull request.
On a related note: Can anybody tell me why there is a
timeFormat: absolute
option? I set my calendar toabsolute
but didn’t notice any difference. -
@yo-less About that last part (getRelative). You might want to add info about it to the calendar readme.
@MichMich I agree with you, which is why you have merged what I have done already :D
https://github.com/MichMich/MagicMirror/tree/develop/modules/default/calendar -
@yo-less lol. Missed that. 😂
@yo-less I want to do the same, what have you done so I can try to do the same on mine?
