    MMM-SmartWebDisplay : display web contents (including YouTube) on your MM
    89 Posts 35 Posters 100.7k Views 38 Watching
      AgP42 Project Sponsor Module Developer
      Hello,
      sorry guys not having answering before, I will try to answer all your questions now !
        AgP42 Project Sponsor Module Developer @Zwirbel
        @Zwirbel Great, thanks that you could confirm it’s works, thanks ! :smiling_face_with_smiling_eyes:
          AgP42 Project Sponsor Module Developer @Anthony
          @Anthony : Yes absolutely ! Did you try it and can confirm it works fine ?
            AgP42 Project Sponsor Module Developer @peterh
            @peterh and @zjonesz : Unfortunatelly I don’t know also how to solve it…
            Maybe someone have a solution ?
            (I have to admit that I am not using that module myself anymore…)
              AgP42 Project Sponsor Module Developer @lukas1760
              @lukas1760 : Normaly yes, any html/css/javascript file can be executed.
              Did you test to be able to confirm that it works ?
                AgP42 Project Sponsor Module Developer @smassy
                @smassy
                the configuration of MMM-SmartWebDisplay seams ok
                I don’t know the module MMM-Assistant2, is it this one : https://github.com/eouia/MMM-AssistantMk2 ?
                If not, can you send me the link on it’s documentation ?
                To be able to send a new url to display to the MMM-SmartWebDisplay, the configuration has to be exactly like that :
                {notification: “SWD_URL”, payload: {url:[“https://magicmirror.builders/”]}}
                This line means : send to the system a “notification” (it is a MagicMirror mecanism) with the topic “SWD_URL” (so my module knows that this notification is for him), and then you have to send a “payload” (extra infos) with the URL you want to use.
                Does that helps ? If yes please let us know the solution !
                Bye,
                AgP
                  smassy
                  @AgP42
                  Thank for answering! :-)
                  Yes the Assistant is https://github.com/eouia/MMM-AssistantMk2
                  I will test with your recommendation and let you know if I’m able to make it work.
                  See ya!
                    smassy
                    @AgP42
                    Good news, I was able to make it work thanks to you! But…there is a but… The youtube link with autoplay is not working :-(
                    This simple url
                    https://www.youtube.com/embed/JGwWNGJdvx8?autoplay=1
                    Will give you ‘video unavailable’ error, remove the autoplay tag and it will show (not play).
                    Trying to find out how to make it work and I will post my config as soon as I get the hang of it.
                    See ya!
                      sdetweil @smassy
                      @smassy are you on version 2.8.0?
                      We put a fix in for video not autoplay
                        smassy
                        Ok I finally got that you were talking about magic mirror, yes it’s 2.8.0. But does it affect smartwebdisplay? I thought the module was independent.
                        • 8
                        • 9
                        • 3 / 9
