    Magic Mirror Redesign WIP :D
    Scheduled Pinned Locked Moved Showcase
    47 Posts 21 Posters 29.4k Views 26 Watching
      smackenzie5 @earlman
      @earlman
      I’m using the default clock, calendar, current weather, and weather forecast. I’m also using google-route. I’d be interested in anything you could do to make the Google map look better in the route module. I assume you don’t care about the modules that run in the background and don’t show on the screen. Thanks
      • ? Offline
        A Former User @earlman
        @earlman
        Looks so nice. I want to try yours.
        1 Reply Last reply Reply Quote -1
        • E Offline
          earlman
          Project Update (& Installation Instructions)
          @skibro @bachoo786 @Sean @smackenzie5
          Alrighty y’all! Got some great news for those who wanna try this setup out. Heads up though—might take a bit of time to set up,
          so don’t expect to get it looking right in a couple clicks.
          First, I’ve added Pexels support to MMM-Wallpaper (thanks @kolbyjack for the quick response).
          As for everything else, all the instructions for setting it up can be found here
          Though I’ve been doing development work for a while, this is one of my first open-source projects, so I’ll definitely do my best to help you guys out if you need it.
          • lavolp3L Offline
            lavolp3 Module Developer @earlman
            @earlman I have to say I really love the grid concept. I have a monitor sitting in the lower right corner of the mirror and a grid design would look much better.
            Can you share your main.css or is it on GitHub?
            Sorry just saw the latest reply with all the information I needed. Thanks man!!
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            E 1 Reply Last reply Reply Quote 0
              @earlman
              Thanks for putting this together.
              Finally had some time to work on this today but got the following error message when running it for the first time:
              pi@raspberrypi:~ $ cd MagicMirror
              pi@raspberrypi:~/MagicMirror $ sudo npm start
              > [email protected] start /home/pi/MagicMirror
              > sh run-start.sh
              Starting MagicMirror: v2.7.1
              Loading config ...
              WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:116
                  				pexels_key: [my API key was here],
              SyntaxError: Invalid or unexpected token
                  at new Script (vm.js:74:7)
                  at createScript (vm.js:246:10)
                  at Object.runInThisContext (vm.js:298:10)
                  at Module._compile (internal/modules/cjs/loader.js:678:28)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                  at Module.load (internal/modules/cjs/loader.js:620:32)
                  at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                  at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                  at Module.require (internal/modules/cjs/loader.js:658:17)
                  at require (internal/modules/cjs/helpers.js:20:18)
              Loading module helpers ...
              Initializing new module helper ...
              Module helper loaded: updatenotification
              No helper found for module: helloworld.
              All module helpers loaded.
              Starting server on port 8080 ...
              Server started ...
              Connecting socket for: updatenotification
              Sockets connected & modules started ...
              Launching application.
              Here’s my config.js:
              			module: "MMM-Wallpaper",
              			position: "fullscreen_below",
              			config: { // See "Configuration options" for more information.
              				source: "pexels",
                  				slideInterval: 60 * 1000, // Change slides every minute
                  				orientation: "vertical",
                  				pexels_search: "beach"
              Thoughts?
              Thanks,
              Scott
                sdetweil @smackenzie5
                @smackenzie5 said in Magic Mirror Redesign WIP :D:
                you need to get a pexels api key and put in where the text says
                  smackenzie5 @sdetweil
                  Yeah, I have the Pexels API key.
                  Replaced it with those words just for the forum post.
                  @earlman
                  BTW - getting the Pexels API key was immediate, no wait
                  Thanks,
                  Scott
                    @smackenzie5 did you put quotes around the key value? If not, that would explain the config error message
                    • E Offline
                      earlman
                      @smackenzie5 nice good news, glad it was quick to get.
                      What sdetweil said, did ya put quotes around the key?
                      • E Offline
                        earlman @lavolp3
                        @lavolp3 Yup, no problem :D hope it works out, if you’re having layout troubles feel free to post a screenshot. Haven’t tested this on a more filled out layout so I’d be curious how it looks
                        • 2 / 5
