    MMM-MplayerRadio
    Scheduled Pinned Locked Moved Entertainment
    46 Posts 7 Posters 13.9k Views 8 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer @electros
      @electros Perfect.
      I think I will check in the script into the repository so you can easy update to upcoming versions
      E 1 Reply Last reply Reply Quote 0
      • E Offline
        electros Project Sponsor @wishmaster270
        @wishmaster270 Thank you
          bryan_1 @wishmaster270
          @wishmaster270 Hi, I’m newbie and know almost nothing about coding. I have installed your module successfully, but what should I do to start it (without touchscreen)? It is shown on my mirror but not played. I put only one Station.
          I want to start it automatically if I start my mirror.
          Thanks.
          wishmaster270W 1 Reply Last reply Reply Quote 0
            wishmaster270 Module Developer @bryan_1
            @bryan_1 Hi, currently there is no autoplay feature implemented. But I will check it the next days. Maybe it is not a big deal
              just published an new version (0.0.3) which provides an autoplay feature. Simply add the station index you want to play to the config option “autoplay”. If you only configured one station it is 0. The station will start to play after about 1 second after the mirror started.
              B 1 Reply Last reply Reply Quote 0
              • ? Offline
                A Former User
                hi @wishmaster270 ,
                if you want me to create a vocal control with MMM-GoogleAssistant, just tell me.
                I can create a special sub-code for your module
                can do:
                • volume control (no api found)
                • change stations (next/previous/play/toogle,etc) from your api
                  wishmaster270 Module Developer @Guest
                  @Bugsounet Hi, great idea. At the moment my mirror is only controlled by sensors and touch.
                  The volume control buttons of my module only send an notification to MMM-Volume that’s way there isn’t any api in this module.
                  Everything else can be controlled by notifications. There is a small section about the notifications in the readme.
                    @wishmaster270 wow, vielen Dank :folded_hands:
                    • ? Offline
                      A Former User
                      @wishmaster270 said in MMM-MplayerRadio:
                      ok so not needed because GA/A2D have native this function (volume control in vocal)
                      I can create quiclky an sample by I don’t know if you use my module
                      Edit:
                      the problem is I can’t send real name of the radio (it’s different with the google Server response)
                      so i will code :
                      SAY To GoogleAssistant NOTIFICATION Sended to MMM-MplayerRadio Function
                      Radio play RADIO_PLAY Playing first station
                      Radio stop RADIO_STOP Stop radio
                      Radio Next RADIO_NEXT Next Station
                      Radio Previous RADIO_PREVIOUS Previous Station
                      Of course all user can change you prefered ‘sentence’ for activate each wanted control
                      Edit 2:
                      [ASSISTANT] Command RADIO_PLAY is executed (notificationExec).
                      MMM-NotificationReceived.js:20 [Notification Sended From][MMM-GoogleAssistant] RADIO_PLAY {}
                      [ASSISTANT] Command RADIO_STOP is executed (notificationExec).
                      MMM-NotificationReceived.js:20 [Notification Sended From][MMM-GoogleAssistant] RADIO_STOP {}
                      [ASSISTANT] Command RADIO_PREVIOUS is executed (notificationExec).
                      MMM-NotificationReceived.js:20 [Notification Sended From][MMM-GoogleAssistant] RADIO_PREVIOUS {}
                      [ASSISTANT] Command RADIO_NEXT is executed (notificationExec).
                      MMM-NotificationReceived.js:20 [Notification Sended From][MMM-GoogleAssistant] RADIO_NEXT {}
                      Tell me if ok, in all case notification are sended.
                      sample of syntax used for send : this.sendNotification("RADIO_STOP")
                      For volume:
                      Vocal Control already coded with GA/A2D : volume 100% for exemple
                      make RPI volume to 100%
                      So don’t worry about this :)
                      Notes:
                      GA: MMM-GoogleAssistant
                      A2D: MMM-Assistant2Display
                      too long to write lol !
                      Sub-Code (recipe) is coded and commit in my dev branch
                      if some users want to test it
                      @bugsounet
                        @Bugsounet Hi, thank you for your work. I checked the code, your notifications should work as planned. Play will start with the last station played or with the first one initially.
                        • 4 / 5
