    Calendar not loading after update
    Scheduled Pinned Locked Moved Troubleshooting
    8 Posts 2 Posters 2.1k Views 2 Watching
      sdetweil @looolz
      @looolz i don’t understand the new url doesn’t work… but downloads the ics
      looks like u have debug turned on in the MM config.js
      also have language set to not english in the MM config
      // change language
      	language: "en",
      // remove ,"DEBUG"
      	logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
      then restart MM…
      the calendar code doesn’t know anything other than what is in the ics file…
      i would be willing to look at it, send the ics to my mail, same userid at gmail
      L 1 Reply Last reply Reply Quote 0
      • L Offline
        looolz @sdetweil
        @sdetweil said in Calendar not loading after update:
        // change language
        language: “en”,
        // remove ,“DEBUG”
        logLevel: [“INFO”, “LOG”, “WARN”, “ERROR”,“DEBUG”],
        Thanks again. I tuned down DEBUG, and the log file made it easier to spot this:
        | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/SECRETSTRING/basic.ics - Interval: 300000
        0|mm     | [31.03.2021 21:11.19.188] [LOG]
        0|mm     | received: SECRETSTRINGn0=
        0|mm     | [31.03.2021 21:11.22.778] [LOG]
        0|mm     | MMM-Ring at (31.3.2021, 21:11:22): Refresh Token Updated
        0|mm     | [31.03.2021 21:11.36.837] [INFO]
        0|mm     | Calendar-Fetcher: Broadcasting 12 events.
        Anything useful to get out of that?
        • L Offline
          looolz @looolz
          And there… without me doing anything. It suddenly is showing events in Magic Mirror! Could it be that the calendar is just to darn big, and that it takes 10-15 minutes for it to process it?
            sdetweil @looolz
            @looolz could be… and with debug on lots longer
            • L Offline
              looolz @sdetweil
              It works now! And it seems to be due to debugging being turned off. Thank you so much for your help!
