MMM-Fitbit2 PythonShell is not a constructor
@frosty_snow Not sure if helpful but I’m using python-shell 0.5.0 and removing the brackets around PythonShell fixed the same error for me.
var NodeHelper = require("node_helper"); const PythonShell = require("python-shell");
this is working for me
@vizulize i think it depends on what version of python-shell you are running…
https://github.com/extrabacon/python-shell/issues/154
your package.json says
"python-shell": "^0.5.0"
which means 0.5.0 OR ABOVE (technically ‘at minimum’)
if u want ONLY 0.5.0, take the ^ off the front…
else sometimes u will get 1.x -
@sdetweil It is defined as 0.5.0 in the dependencies.
To be honest, the Python should be rewritten in JS anyway. Perhaps I will get around to doing that in the near future :thinking_face:
Then this issue goes away!
@vizulize yeh, i don’t know whay there is a python_shell lib… as exec and spawn are so easy…
