    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 283.3k Views 30 Watching
      sdetweil
      For any that want to look at the multi-module form layout and give feedback
      checkout the multi-module branch
      git checkout multi-module
      there is a file that contains the list of module names that CAN be used multiple times in the same config.js
      modules_list.txt
      you cannot submit the form, only view it…
      to go back to the operating version
      git checkout main
      or
      (with the .... fixes)
      git checkout newform
        stoffel @sdetweil
        i did it. WOW, all works well. thanks, great job and fast :thumbs_up:
        but it works only when i open …/review or must add ‘?port=8300’ at …/config.html
        thank you very much :-)
          sdetweil @stoffel
          @stoffel said in Are you tired of editing config.js, or have trouble doing it, see my new module:
          well, i need a free port to have the two parts communicate.
          I had ‘guessed’ at a free port, but some other users had stuff running there
          so, I have it get a free port, but now I have to pass that to the form side…
          use the review URL , it will always redirect to the correct url
          it will probably never change on your system , so once u know what the number is, use that url…
            stoffel @sdetweil
            ok, thanks for you support. great job !
            i follow this tread and test your module. but in the next days i am a little bit busy.
            so, @ all have a nice WE
              sdetweil @stoffel
              @stoffel thanks for your help!..
              I need people like you to help improve the module. every bug found now helps…
                stoffel @sdetweil
                thanks ;-)
                and i like people like you who spent a lot of time for creating useful modules like this !!
                again thanks a lot
                • BKeyportB Offline
                  BKeyport Module Developer
                  So, I’m getting the header and nothing else.
                  fresh install of MagicMirror using the script, PM2. Here’s my config, as you can see, the only changes are the listening address, the ipWhitelist, and the addition of the module as shown in the readme.
                  modules I installed (but didn’t configure for testing) were MMM-Config, MMM-Multimonth, and MMM-OpenWeatherForecast.
                  var config = {
                          address: "0.0.0.0",     // Address to listen on, can be:
                          port: 8080,
                          basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                          ipWhitelist: [],        // Set [] to allow all IP addresses
                          useHttps: false,                // Support HTTPS or not, default "false" will use HTTP
                          httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                          httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                          language: "en",
                          locale: "en-US",
                          logLevel: ["INFO", "LOG", "WARN", "ERROR"], // Add "DEBUG" for even more logging
                          timeFormat: 24,
                          units: "metric",
                          // serverOnly:  true/false/"local" ,
                          // local for armv6l processors, default
                          //   starts serveronly and then starts chrome browser
                          // false, default for all NON-armv6l devices
                          // true, force serveronly mode, because you want to.. no UI on this device
                          modules: [
                                  module:"MMM-Config",
                                  position:"top_right",  // the QR code (if requested) will appear here
                                  config:{
                  ... (no changes after this point)
                    sdetweil @BKeyport
                    @bkeyport if u open the developers window, ctrl-shift-i, and select the console tab. are there errors shown
                    also if u look in the pm2 logs, are there problems.
                    do a
                    and try again. lots of fixes there
                    the latest code requires a port number to be passed to the form page… use the review link
                    http://mm_ip:mm_port/modules/MMM-Config/review
                    (thats the url on the qr image)
                    BKeyportB 1 Reply Last reply Reply Quote 0
                    • BKeyportB Offline
                      BKeyport Module Developer @sdetweil
                      Failed to load resource (Connection refused) http://IP:8200/socket.io/?EIO=4&transport=polling&t=NchkO1_
                      DevTools failed to load SourceMap: Could not load content for http://IP:8080/modules/MMM-Config/node_modules/jsonform/deps/opt/bootstrap.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                      Then repeated
                      (anonymous) @ VM6:1
                      create @ polling-xhr.js:198
                      Request @ polling-xhr.js:115
                      request @ polling-xhr.js:62
                      doPoll @ polling-xhr.js:90
                      poll @ polling.js:74
                      doOpen @ polling.js:23
                      open @ transport.js:44
                      open @ socket.js:194
                      Socket @ socket.js:119
                      ./node_modules/engine.io-client/lib/index.js.module.exports @ index.js:3
                      open @ manager.js:112
                      (anonymous) @ manager.js:342
                      VM6:1 GET http://IP:8200/socket.io/?EIO=4&transport=polling&t=NchkPo7 net::ERR_CONNECTION_REFUSED
                        sdetweil @BKeyport
                        @bkeyport did u use the review link, its probably port 8300 now
                        see the instructions here
                        https://github.com/sdetweil/MMM-Config/issues/8
                        • 6
                        • 7
                        • 29
                        • 30
                        • 5 / 30
