    MMM-CalendarExt2
    486 Posts 83 Posters 751.2k Views 83 Watching
      sdetweil @ccr41981
      @ccr41981 no idea
      2 things
      1 look for messages where you start MM
      npm start
      2, open the developers window, mm screen, ctrl-shift-i, select the tab labeled ‘console’ and then put a unique part of the module name in the filter field (ext for example)
      C 1 Reply Last reply Reply Quote 1
        ccr41981 @sdetweil
        @sdetweil Yikes, ok, I’ll figure out what all that means.
        I’ve only been running it in server mode, since I haven’t been able to resolve the Display error to make it run as it’s own instance. I’ll try and resolve that and do these steps.
        C S 2 Replies Last reply Reply Quote 0
          ccr41981 @ccr41981
          @ccr41981 said in MMM-CalendarExt2:
          AS YOU WERE. For some unknown reason, the calendar just popped up
            sdetweil @ccr41981
            @ccr41981 display error
            https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/226?_=1642092517613
              ccr41981 @sdetweil
              @sdetweil I’ve been through those posts about the display error, but i will go back and try to troubleshoot again.
              However, the calendar did just pop up, so now I can go tinker with the look and set up my interface. Thanks for your help.
                sdetweil @ccr41981
                note that on node 16 the format of the correction has changed from prior posts
                  ccr41981 @sdetweil
                  @sdetweil Gotcha! Thanks again
                    ccr41981 @sdetweil
                    @sdetweil said in MMM-CalendarExt2:
                    @ccr41981 you’ve read the config doc?
                    https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/master/docs/Configuration.md
                    use the example, and your url .
                    also, this module suffers from a missing library ( that was removed from the base a couple releases back )
                    in the module folder (MagicMirror/modules/MMM-CalendarExt2) do
                    npm install request --save
                    Works great now! Thanks for your help
                      ccr41981 @ccr41981
                      @sdetweil One last question; would you know why CalendarExt2 doesn’t show up on the remote module? Not that I’d ever turn it off, just curious.
                        sdetweil @ccr41981
                        @ccr41981 on the remote?
                        • 42
                        • 43
                        • 44
                        • 45
                        • 46
                        • 47
                        • 48
                        • 49
                        • 44 / 49
