    325 Posts 26 Posters 485.3k Views 23 Watching
      sdetweil @gonzonia
      @gonzonia also, make sure you back up…
      https://github.com/sdetweil/MagicMirror-backup-restore
        sdetweil @gonzonia
        @gonzonia so the prior version install of node20 went ok as expected.
        but I don’t see the ‘npm’ item in the install list
        Reading state information... Done
        Suggested packages:
          npm  <-------  I don't see this
        The following NEW packages will be installed:
          nodejs
        0 upgraded, 1 newly installed, 0 to remove and 20 not upgraded.
        so lets do the uninstall again
        and then try
        sudo apt remove npm
        G 1 Reply Last reply Reply Quote 0
          gonzonia @sdetweil
          After an uninstall it says npm isn’t installed. I tried the install again and it’s still installing 12.22.12
          I did the backup. I’m just going to rebuild. It’s annoying but it should work. :crossed_fingers_light_skin_tone:
            sdetweil @gonzonia
            @gonzonia one more try… got some feedback from node user
            hang on while I do a quick test
            do this
            sudo cat  /etc/apt/sources.list.d/nodesource.list
            I see
            deb [arch=arm64 Pin-Priority:600 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
              gonzonia @sdetweil
              pi@MagicMirror2:~ $ sudo cat  /etc/apt/sources.list.d/nodesource.list
              deb [arch=arm64 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                sdetweil @gonzonia
                @gonzonia ok, suggestion was to add the pin-priority
                try the node20_install.sh again from my repo
                  gonzonia @sdetweil
                  Same thing. I feel like this line is the issue ----“Selecting previously unselected package nodejs.” How can I clear wherever it’s finding that?
                  (I also tried the uninstall from your repo and install, same thing)
                  pi@MagicMirror2:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)"
                  Reading package lists... Done
                  Building dependency tree... Done
                  The following packages were automatically installed and are no longer required:
                    libc-ares2 libjs-highlight.js libnode72 nodejs-doc
                  Use 'sudo apt autoremove' to remove them.
                  The following packages will be REMOVED:
                    nodejs*
                  0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                  After this operation, 919 kB disk space will be freed.
                  (Reading database ... 107017 files and directories currently installed.)
                  Removing nodejs (12.22.12~dfsg-1~deb11u4) ...
                  Processing triggers for man-db (2.9.4-2) ...
                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  ca-certificates is already the newest version (20210119).
                  curl is already the newest version (7.74.0-1.3+deb11u7).
                  gnupg is already the newest version (2.2.27-2+deb11u2).
                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  Get:1 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                  Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Get:4 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [3,264 B]
                  Fetched 15.4 kB in 1s (16.3 kB/s)
                  Suggested packages:
                    npm
                    nodejs
                  0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                  Need to get 0 B/148 kB of archives.
                  After this operation, 919 kB of additional disk space will be used.
                  (Reading database ... 106955 files and directories currently installed.)
                  Preparing to unpack .../nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb ...
                  Unpacking nodejs (12.22.12~dfsg-1~deb11u4) ...
                  Setting up nodejs (12.22.12~dfsg-1~deb11u4) ...
                  update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
                    sdetweil @gonzonia
                    @gonzonia can u cat that file again
                      gonzonia @sdetweil
                      deb [arch=arm64 Pin-Priority=600 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                        sdetweil @gonzonia
                        @gonzonia hmmmm… ok, don’t know… I will post that too…
                        best to just move to new again I guess…
                        can u try this
                        sudo apt-get update
                        sudo apt-get install nodejs -y
                        • 29
                        • 30
                        • 31
                        • 32
                        • 33
                        • 32 / 33
