    Show date below time and date info on several lines
    Scheduled Pinned Locked Moved Showcase
    1 Posts 1 Posters 2.1k Views 1 Watching
    • oscarbO Offline
      oscarb
      Hi!
      Just thought I would share how I put the date below the time for the default Clock module using only CSS - no need to modify or create your own clock module!
      custom.css
          CLOCK
      #module_2_clock > div > div {
          display: flex;
          flex-direction: column;
      /* Date */
      #module_2_clock > div > div > div.date {
          order: 2;
      /* Time */
      #module_2_clock > div > div > div.time {
          order: 1;
          font-family: Roboto, sans-serif;
          font-weight: 300;
          font-size: 80px;
          line-height: 75px;
          letter-spacing: -3px;
          color: #fff;
      Also, to show the week on a separate line and make it a little bit smaller, use HTML tags within brackets when setting the date format, like this:
      config.js
        module: "clock",
        position: "top_right",
          displaySeconds: false,
          dateFormat: "dddd D MMMM[< br/ >< small >vecka] W[< /small >]",
      NOTE: Since the forum is sanitising HTML, remove all the spaces from the tags above in < small >, < /small > and < br/ > to make it work.
      Hope this can inspire and help someone! :)
