    Family Info Board
    Scheduled Pinned Locked Moved Showcase
    40 Posts 19 Posters 52.9k Views 33 Watching
      Padilla187 @Wedee
      @Wedee don’t want to be a wierdo but I fell in love with this I Just shot you a pm
      • O Offline
        Orca
        @Wedee : How did you the trick with several calendars? Could you please share some infos for me?
        Thx
        lucallmonL 1 Reply Last reply Reply Quote 0
        • lucallmonL Offline
          lucallmon @Orca
          @Orca simply clone the module for the calendar and change the settings for login.
          • O Offline
            Orca
            @lucallmon: Can you give me a hint how to clone this module. I’ve copied the folder into …/modules and named it calendar1, but only black screen.
            Thx
            • W Offline
              Wedee
              No need to duplicate the module, in the config.js just repeat the module config but point to the second calendar settings.
              • yawnsY Offline
                yawns Moderator
                You have two possibilities with the calendar module.
                Option 1:
                This shows one block and mixes both calendars, sorted by date
                modules: [
                		module: 'calendar',
                		header: 'both calendars'
                		position: 'top_left',
                			calendars: [
                				url: 'http://www.whatever.....xx.ics',
                				symbol: 'calendar',
                				url: 'http://www.justanother....zz.ics',
                				symbol: 'calendar',
                Option 2:
                This show calendar1 sorted by date and then shows calendar2 sorted by date, but in a seperate block with a seperate header
                modules: [
                		module: 'calendar',
                		header: 'calendar1'
                			calendars: [
                				symbol: 'calendar',
                		module: 'calendar',
                		header: 'calendar2'
                			calendars: [
                				symbol: 'calendar',
                JohanbaJ 1 Reply Last reply Reply Quote 3
                • O Offline
                  Orca
                  THX, that did the trick.
                    dsegel
                    Another request for you to post your css for calendar_monthly…I’m not having much luck getting it formatted widely enough.
                      emos
                      Very clean.
                      Can i ask, how did you manage to create horizontal lines for all the modules?
                      W 1 Reply Last reply Reply Quote 0
                      • W Offline
                        Wedee @emos
                        @emos I believe its just a function of my CSS forcing column widths (width: xxxpx;). As the headers of the module are usually set to “float” the forcing of a width makes them span the entire column.
                        I have not touched the mirror in about a year - it just runs.
                        • 3 / 4
