Family Info Board
@Wedee Thank you for your reply.
Do you mind sharing your main.css and custom.css with us? It looks too damn good ;) -
@emos Shoot me a PM with your email and I will add you to the dropbox share i have of the files.
@wedee I like your design. I’m just getting started on my MagicMirror. Do you mind adding me to the Dropbox share? Thanks!
@Wedee : Hello Wedee -> i send you a PM with my email address. Would it be possible for you to share your main.css and custum.css? thanks a lot
@Wedee I messaged you with my email address awhile back as well.
I edited the main post with more info… sorry it took so long.
@Wedee, Thanks for taking my message.
I am crazy about your format, but coping the Custom.css just crash my MM completely.
Will someone please share their Main.css, Custom.css and config.js with me on [email protected]I will appreciate this
Johan
@yawns
Hi, I copied this to my Config.js
Then I get a syntex error on the position in both scenarios
Appreciate the support -
@johanba could you post the ‘what you copied’…
back two pages and can’t find it…
I imagine the Custom.CSS failure is related to the fact that its calling for an image. I would remove the two lines related to the Background and see if it works then. Other than some colors and of course the forcing of the column widths there is not really much in the custom.css
In the config.js I sent you via email - you will see I changed to using the module MMM-Profilepicture pointing back at localhost to host backgrounds there. It is much cleaner easier to use. I also switched from wunderlist to todoist for the todo list…
I have not done much other than change the background for many years now - Wife is asking for a refresh, and we picked up a Narrow hutch someone was throwing away that with a coat of paint some new handles and a new monitor will make for an excellent info board - so once that is refinished i will start anew again but this time the screen will be in portrait.
Good luck and happy learning
