    Error when trying to install the MagicMirror 2.
    errormagicmirror2newbie
    4 Posts 2 Posters 1.5k Views 2 Watching
      Doogain
      Hi there.
      I was hoping that someone here might be of assistance, since Im completely new to this and I tried to install the MagicMirror2 on my Raspberry Pi 3.
      Its a SD card with a fresh installed Raspbian from this source https://www.raspberrypi.org/downloads/raspbian/
      Installed the desktop with recommened software version.
      I ranthis in order to install MagicMirror2
      bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
      This is the error Im getting.
      npm WARN npm npm does not support Node.js v10.15.2
      npm WARN npm You should probably upgrade to a newer version of node as we
      npm WARN npm can't make any promises that npm will work with this version.
      npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
      npm WARN npm You can find the latest version at https://nodejs.org/
      npm WARN tar write after end
      npm WARN notice [SECURITY] randomatic has the following vulnerability: 1 low. Go here for more details: https://www.npmjs.com/advisories?search=randomatic&version=1.1.7 - Run `npm i npm@latest -g` to upgrade your npm version, and then `npm audit` to get more info.
      npm WARN notice [SECURITY] moment has the following vulnerability: 1 low. Go here for more details: https://www.npmjs.com/advisories?search=moment&version=2.18.1 - Run `npm i npm@latest -g` to upgrade your npm version, and then `npm audit` to get more info.
      npm ERR! cb() never called!
      npm ERR! This is an error with npm itself. Please report this error at:
      npm ERR!     <https://github.com/npm/npm/issues>
      npm ERR! A complete log of this run can be found in:
      npm ERR!     /home/pi/.npm/_logs/2019-10-23T20_51_28_225Z-debug.log
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! [email protected] install: `cd vendor && npm install`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the [email protected] install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/pi/.npm/_logs/2019-10-23T20_51_28_705Z-debug.log
      Unable to install dependencies!
      Once again, Im new to this whole raspberry pi world, never used one before yesterday. If you can answer me in terms that even a baby would understand, Id really appreciate it.
      Thanks in advance.
        sdetweil @Doogain
        @Doogain the stock installer has trouble with changes made by the dependencies…
        I have an updated one we are testing
        please give it a try
        see
        https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer/2
          Doogain @sdetweil
          You’re the man, worked like a charm. This solution needs to be more widely known!
            sdetweil @Doogain
            @Doogain I submitted the changes to the project this morning so in the next release they should be included
