    https://github.com/njwilliams/MMM-PlaceInfo not loading
    6 Posts 4 Posters 522 Views 4 Watching
      GoodWillGustin
      Does anyone else use this module/anyone having trouble with it?
      I got my API keys and set up the config file. When I launch MM, not only does the PlaceInfo module not load (when set to either top_center or bottom_center), but none of my modules will load besides top_left, top_center, and middle_center regions. I’m getting no errors in the terminal. Here is my config.js entry:
      module: 'MMM-PlaceInfo',
      position: 'top-center',
      weatherAPIKey: "myopenweatherAPIkey",
      currencyAPIKey: "myfixer.ioAPIkey",
      currencyPrecision: 2,
      currencyRelativeTo: 'USD',
      places: [
      title: "London",
      flag: "gb",
      currency: "GBP",
      timezone: "Europe/London",
      weatherID: "2643743",
      title: "Tokyo",
      flag: "jp",
      currency: "JPY",
      timezone: "Asia/Tokyo",
      weatherID: "1857910",
        Dresch360 Project Sponsor
        I’m having the same issue. Any updates?
          sdetweil @Dresch360
          @dresch360 can u open the developers window. ctrl-shift-i on the mirror keyboard and select the console tab
          Z 1 Reply Last reply Reply Quote 0
          • Z Offline
            Zoltan @sdetweil
            @Dresch360
            I suspect it is a “,” issue but I also cant seem to figure it. Did you manage?
              sdetweil @Zoltan
              @Zoltan the latest problems are because
              Openweayher changed their business model and require user to supply credit card to use the new /onecall endpoint
              So you have to set apiversion to 3.0 and the endpoint to /onecall
              • Z Offline
                Zoltan @sdetweil
                Thanks very much for the heads up. I remember now when one of my displays crashed due to the 2.5 that had to be changed to 3.0. Thanks for the quick response
