Adding shared Google calendars
I’ve tried to add shared Google calendars, but it just doesn’t show any of the events. I assume it has to do with the credentials. Here’s a copy of my config file for that section. Note that the calendar is not publicly visible and it has to stay that way. Also, I have tried all three options for the “method” section and none seems to make a difference.
Here’s the config file I’m using:
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en", timeFormat: 12, units: "imperial", colored: true, // serverOnly: true/false/"local" , // local for armv6l processors, default // starts serveronly and then starts chrome browser // false, default for all NON-armv6l devices // true, force serveronly mode, because you want to.. no UI on this device modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "Customer Schedule", position: "top_left", config: { calendars: [ { symbol: "calendar-check", url: "https://calendar.google.com/calendar/embed?src=OURDOMAIN.com_XXXXXXXXXXXXXXXXXXXXXXXXX%40group.calendar.google.com", auth: { user: '[email protected]', pass: 'PASSWORD', method: 'basic' // I have tried all three options for this } } ] } }, { module: "currentweather", position: "top_right", config: { location: "New York", locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "New York", locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true, broadcastNewsFeeds: true, broadcastNewsUpdates: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;}
@cyrus u need the public or secret url link of the calendar
this is not it, this is the embed link
on the calendar.google.com site, select the calendar lower left, 3 dots,
select settings
select integrate calendarselect either the public address in iCal format, or the secret address in iCal format
Thanks for your help. That was indeed the problem.
@cyrus cool. Glad u got it working!
