    Making my first module: issue with notifications
    notificationsmodulemagicmirror
    8 Posts 2 Posters 1.1k Views 2 Watching
      rico24 Module Developer
      Hi all,
      I tried to follow the following instructions First module to make my first module.
      I have it running on my Raspberry PI, but it results in showing only the original count value of 100000 and doesn’t count down. My question is: what am I doing wrong?
      Javascript file
      /* Magic Mirror
       * Module: name of module
      //Register module
      Module.register("MMM-DutchGarbageCalendar", {
        defaults: {
              foo: "I'm alive!"
        //Start function
        start: function (){
              count = 0
       //getDom Function
        getDom: function() {
        var element = document.createElement("div")
        element.className = "myContent"
        element.innerHTML = "Hello, World! " + this.config.foo
        var subElement = document.createElement("p")
        subElement.id = "COUNT"
        element.appendChild(subElement)
        return element
      //NotificationReceived
      notificationReceived: function(notification, payload, sender) {
              switch(notification) {
                      case "DOM_OBJECTS_CREATED":
                              var timer = setInterval(()=>{
                                      this.sendSocketNotification("DO_YOUR_JOB", this.count)
                                      console.log("notificationReceived: DO_YOUR_JOB:")
                                      this.count++
                              }, 1000)
                              break
       //socketNotificationReceived
      socketNotificationReceived: function(notification, payload) {
                      case "I_DID":
                              var elem = document.getElementById("COUNT")
                              elem.innerHTML = "Count:" + payload
                              console.log("socketReceived:" + payload)
                              break
      node_helper
      var NodeHelper = require('node_helper');
      var request = require('request');
      module.exports = NodeHelper.create({
              start: function() {
              this.countDown = 100000
                      console.log("Payload: =" + this.payload);
                      switch(notification){
                              case "DO_YOUR_JOB":
                                      this.sendSocketNotification("I_DID", (this.countDown - payload))
                                      console.log("Payload 2: = " + payload);
                                      break
      Who can help me out?
        sdetweil
        tiny things
        module file
        was no ‘count’ variable
        also needs to be ‘this.count’ (variable of object instance)
        /* Magic Mirror
        //Register module
          defaults: {
                foo: "I'm alive!"
          count:0,
          //Start function
          start: function (){
                this.count = 0
         //getDom Function
          return element
        			console.log("send socket notificationR: DO_YOUR_JOB:"+this.count)
                                this.count++
                                }, 1000)
                                break
                        case "I_DID":
                                break
        node helper
        NOT use this… this.payload
                countdown: 0,
                start: function() {
                        console.log("Payload: =" + JSON.stringify(payload));  // < --- not this. is a parm passed to function
                                case "DO_YOUR_JOB":
                                        let new_payload = this.countDown - payload)
                                        this.sendSocketNotification("I_DID", new_payload)
                                        console.log("Payload 2: = " + new_payload);
                                        break
          rico24 Module Developer @sdetweil
            sdetweil
            did u open anther browser window with the MM loaded into it? it will start another instance of the the module.js (with its own counter)
              @sdetweil Thank you!
              It was because I opened one tab and then closed it, open a new one but the timer was still running indeed. When in the future I want to do something with the mechanisme I need to solve this ;)
              Now I now how notifications work in practice, I can finish my own module :)
                sdetweil @rico24
                @rico24 u can also look at my sample module, which accesses config, does notifications,. etc
                https://github.com/sdetweil/SampleModule
                to fix the problem, you need to send the module identifier in the payload, and have different counters, stored by identifier… when u send back from the helper EVERY module gets notified at once,
                so they need to look at the identifier returned to make sure the message is for them, and ignore others
                  sdetweil
                  this is what that would look like… as u want pages insulated from each other as well as module instances
                  module
                  /* Magic Mirror
                  //Register module
                    defaults: {
                          foo: "I'm alive!"
                  	ourpage: Math.ceil(Math.random() * 100),
                  	count:{},
                    //Start function
                    start: function (){
                    this.count[this.ourpage] = 0
                   //getDom Function
                    return element
                  		        Log.log("send socket notificationR: DO_YOUR_JOB:"+this.count[this.ourpage])
                  			this.sendSocketNotification("DO_YOUR_JOB", {identifier: this.identifier+this.ourpage, value:this.count[this.ourpage]})
                                                  this.count[this.ourpage]++;
                                          }, 5000)
                                          break
                                  case "I_DID":
                  			if(payload.identifier== this.identifier+this.ourpage){
                  				elem.innerHTML = "Count:" + payload.value
                  				Log.log("socketReceived:" + JSON.stringify(payload))
                  			else
                  		        	Log.log("notification not for us");
                                          break
                  helper
                  		initial_counter:10000,
                          start: function() {
                  					this.countDown = {}
                                          case "DO_YOUR_JOB":
                                    		if(!this.countDown.hasOwnProperty(payload.identifier+this.ourpage)){
                  					this.countDown[payload.identifier]=this.initial_counter;
                  				let return_payload={identifier: payload.identifier, value:(this.countDown[payload.identifier] - payload.value)}
                                                  this.sendSocketNotification("I_DID",return_payload )
                                                  console.log("Payload 2: = " + JSON.stringify(return_payload));
                                                  break
                    sdetweil @sdetweil
                    @rico24 and here is an updated node_helper, that rejects connecting clients if they don’t send the right kind of identifier (ends with a digit)
                            start: function() {
                    			this.countDown = {}
                    	isDigit: function(x){
                    			return (x>='0' && x< ='9')  // watch out for spaces after < , forum hides it all
                                            case "DO_YOUR_JOB":
                    				if(this.isDigit(payload.identifier.slice(-1))){
                    			else
                    				this.sendSocketNotification("I_DID_REJECTED_INVALID_IDENTIFIER",payload )
                                                    break
