    MMM-SynologySurveillance
    34 Posts 5 Posters 15.4k Views 5 Watching
      digied @wishmaster270
      @wishmaster270 I did some research. Somehow the network wasn’t right anymore. The cam got a different ip-address, so it was rebooted somehow and using DHCP got a different address. Now it is set to the same address. I did replace the first switch to which the NAS and the cam are connected. For the cam I use a repeater that uses the electrical net to connect to my backbone. A cable would have been difficult. After a reset of all that components, the cam was reconnected and all is working again.
        m3iaz
        Hi. I love Your module.
        Do You know if there is a way to get better resolution than width of 320px?
        I mention width only since I have one 4/3 cam and 3 reolink duo which is 8/3.
        For all of it, best quality I can get is 320/xxx.
        By many experiments I have found that this is best I can get and enlarging it with method you posted will drop in quality.
        I think it can be somewhere in DSP configuration but can not find it at all…
        BTW. none of my cameras provide mjpeg stream but can provide jpeg snapshots. Maybe it is worth to implement this solution as well…
        wishmaster270W 1 Reply Last reply Reply Quote 0
        • wishmaster270W Offline
          wishmaster270 Module Developer @m3iaz
          @m3iaz Hi,
          the Reolink cams provide a fluent and a high quality stream.
          You can select three different stream types in the Surveillance Station. The MJPEG stream is generated of the one for reduced speed which in my setup is the fluent stream of the Reolink cam.
          I can select a 640x stream in my Reolink but it may depend of the camera.
          I do not have much time to program at the moment but you may checkout my EmbedURL module. It is able to embed images and a refresh rate can be configured. Some people use it to embed JPEG of public webcams already.
          BKeyportB M 2 Replies Last reply Reply Quote 0
          • BKeyportB Offline
            BKeyport Module Developer @wishmaster270
            @wishmaster270 and through use of an old pi for MotionEyeOS, I use it to embed a near-direct stream from my Reolink cameras. :)
              m3iaz @wishmaster270
              @wishmaster270 Thank You for quick answer. I will try it
              • 4 / 4
