    MMM-Multimonth
    calendarmagicmirror2module
    77 Posts 19 Posters 33.1k Views 17 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      MagicMirror Module to display a calendar with multiple months
      A mini-calendar with as many months as the user wants, assuming screen space is available.
      Download
      https://www.github.com/BKeyport/MMM-Multimonth
      [card:BKeyport/MMM-Multimonth]
      Installation
      Clone this repository in your ~/MagicMirror/modules/ folder ( $ cd ~MagicMirror/modules/ ):
      git clone https://github.com/BKeyport/MMM-Multimonth.git
      Using the module
      To use this module, add it to the modules array in the config/config.js file:
        module: 'MMM-Multimonth',
      	position: 'top_left', // can be any of the postions
      	config: { // Optional - will default to 3 months, with one previous and one next.
      	  startMonth: -1, // Define when you start from current month (negative is before current, zero is current, positive is in future)
               monthCount: 3, //  How many months to display
               highlightWeekend: false // highlightWeekend if desired, set to true.
      Many thanks to kirash for the inspiration with the monthly_calendar module, sdetweil and lavolp3 for the help in coding and CSS work. Without your help, this would just be a pipe dream.
      This is a basic module, but I felt it was good enough for release to the public.
      Please, if you have any suggestions for improvement, let me know, I’m learning Javascript and CSS as I write this, and I dream of much bigger things.
      ~~Localization is provided by moment.js and controlled by the master language of MagicMirror. Please file any errors with localizations as bugs with the moment.js team - https://github.com/moment/moment/~~
      Please see github for version info and further instructions.
      BKeyportB 1 Reply Last reply Reply Quote 6
        ShoeBox
        @BKeyport this is great! Thank you. Is there a way to change the colors?
          matelot20
          @BKeyport I would like to know as well if the header color can be changed.
          • BKeyportB Offline
            yes. It’s all in CSS. Take a look at the CSS file in the directory, and copy over to your custom.css
              PH1TCH
              @BKeyport Great MMM, exactly what I was looking for! :winking_face: Can the first day of the week be changed to monday?
              • BKeyportB Offline
                BKeyport Module Developer @PH1TCH
                @PH1TCH It’s in the notes I haven’t figured out how to do this yet. Everything I’ve tried has failed due to API issues. I’m cracking on it when I can. My business takes priority, and we’ve been extended out due to this whole virus thing.
                  PH1TCH @BKeyport
                  @BKeyport Okay, thanks for the update!
                  • W Offline
                    Werner1340
                    Hello, how can I change the color from grey (days+numbers) from grey to white?
                    • BKeyportB Offline
                      BKeyport Module Developer @Werner1340
                      @Werner1340 That’s actually a magicmirror default. I believe it’s getting it from here:
                      .normal {
                        color: #999;
                      W 1 Reply Last reply Reply Quote 0
                      • W Offline
                        Werner1340 @BKeyport
                        @BKeyport Hm, i found that code in the main.css and changed the color to #fff.
                        …still grey color in calendar. ;-). any more Ideas?
                        • 5 / 8
